Steel, 1/16" thick. Anyone?
Thanks in advance.
Thanks in advance.
I believe they are cooling fan mounting brackets
Designed to use only if using a Mustang donor rad fan shroud, with the standard FFR supplied electric fan,
Ditto On The Fan Support Brackets!
OK, thank you guys. No trip to the powder coater for these, then...
You also have some goofy looking brackets to install hood pins instead of the hood hinges.
Save them both because you may hack them up to use for other things down the road.
I've used my two of the quick jacks to make my sway bar mounts and my hood pin brackets as part of my lower radiator support.
