WTB CMCV from 2015-17 coyote
If any forum members have the CMCV parts (charge motion control valve actuators) left over from installation of block off plates on the back of a 2015-17 coyote mustang or F150 intake manifold I would be interested in purchasing the same. I have to replace some damaged parts on the 2016 F150 "pull out" that I will be using on my Mk 4 roadster build and it looks like the only way to get these items from Ford is to buy a complete intake manifold.
Problem solved found a 2016 mustang gt manifold on ebay complete with fuel rails, injectors and throttle body that had been removed for installation of a Rousch kit.
Reason: parts found
