Results 1 to 5 of 5
Thread: How many of you...
    Banned
    How many of you...
    ...forgot or didn't know you need to remove the output shaft race from the tail-housing when you do the 2WD conversion?
    That bad boy has been bouncing around back there for 500+ miles.
    It's a slip fit into the bore that's above the main shaft, so if you didn't remove it, it's probably fallen out and loose.
    NYC
    I've done that, but luckily realized it before I installed the trans.
    Banned
    I made sure to do it on the new trans
    I should have known better with all the times I've had a 5MT apart but I never even thought of it until I pulled the block off plate off. Always freaked me out a bit how loose those are "pressed in" from the factory.
    NYC
    Happens to the best of us.
    Tallahassee, Florida
    I did not see anything in the instruction manual about this. I am right at this point, thanks a million for this information.
