Results 1 to 10 of 10
Thread: help for ID aluminum pieces
    Saline, Mi
    IMG_0955.JPG looks like under battery but too small
    IMG_0958.JPG Is this door latch template or door handle template or are same?
    IMG_0960.JPG Is this 81030 felted 3/8
    Thanks for any help.
    Mechie3's Avatar
    953: door card inserts?
    956: diffuser canards
    Fenton MI
    Frank you got the coupe right? Thinking back to my inventory...
    953 looks like the interior door handle template from the street version that used the WRX pull handles, coupes came with interior door handles.
    958 is for locating the exterior door handles
    Factory Five 818c #456
    Saline, Mi
    Yes, I have coupe. Thanks Craig and Shawn. Only
    couple more to find.
    It is hard to understand the scale of 955 on your picture. Is it possible you engine belly pan?
    Saline, Mi
    I have the eng belly pan. 955 has minor length of 22 by major of 32 and 11 in high.
    960 is the exterior side window gasket for the doors.
    953 I verify mechie3, these are the interior door card inserts. You can use them to locate the door pulls - but if you have the padded door cards they will not match the inset perfectly. I had to eyeball it based on reusing the door pull controls from the donor. Revisions to the kit now include different door pull hardware (not from donor) and cables to use instead of the donor pull hardware. Let me know if you need more details.
    Saline, Mi
    can anyone id this steel bracket. I am thinking it could be an exhaust mount??IMG_0998.JPG
    Bowling Green, KY
    That is the throttle pedal mount for the cable actuated throttle.
    Saline, Mi
    Thanks Mitch
