Page 2 of 2 FirstFirst 12
Results 41 to 51 of 51
Thread: Body fitment on 3/4" front frame rails
    So. Bay (So. Calif.)
    Gentlemen,
    I'm not familiar with McMaster.
    How can I locate them?
    I didn't think you could build a car without McMaster-Carr.
    I will caution you that this may be one of those cases where trying to reinvent the wheel to make something "better" can ultimately make life difficult later (specifically for the body guy). Just sayin'...
    Just let the body guy fix it. At least if his name is Jeff. The Jeff's can fix anything.
    Quote Originally Posted by boat737 View Post
    Very nice Paul. Do you by chance remember the McMaster number for the closed cell foam you used?
    Gentlemen,
    The foam I used for the hood outline was McMaster 8512K96. https://www.mcmaster.com/#8512k96/=16w814b. The 25 foot piece was enough for #7750 and the Anniversary build. It's 1/2-inch thick but was thick enough to fill the opening on both builds, and is in the pictures I posted.
    Haven't heard of McMaster? Heresy! I couldn't build one of these without them. Their website is easy to use, fully documents the parts they have (which is amazing), and for me with a distribution center near Cleveland, I always get the parts the next day. True they don't provide the shipping cost until after you order. But I find their shipping charges very reasonable. Pays of course to combine wherever possible, but typically it's near the actual UPS amount without a bunch of markup. Highly recommended source. I choose not to add up how much of my build budget is spent there.
    Senior Member Norm B's Avatar
    I didn't use pop rivets to hold the rubber snubbers in place around the hood opening. They won't allow you to adjust the body to follow the hood shape. I drilled and tapped the 3/4 inch tube for machine screws at each snubber location. I waited about a week after the final body installation, to let the body settle and find its final shape on the frame, then used the machine screws to match the hood opening and hood height. Once I had the height where I wanted it, I removed and re installed the screws, one at a time, with a little blue loctite on them. They haven't moved in three years.
    HTH
    Norm
    Point Well Taken!
    I'll know when I test fit the body again if this is a good or bad idea.
    Thanks for being the Devils Advocate on this issue because I've stubbed more than a few toes with my off beat build.
    I agree with Jeff. This has really not been a complicated issue in the past. Re-read Edward's comments in the bottom of his post #29.
    O'Fallon, MO
    What, I can't reinvent the wheel and totally ignore the advice give here, go ahead and fix a problem NO one has had.. how dare you.
    But I Love Reinventing The Wheel!
    https://youtu.be/_wnHDNgnNqs
    Makes life interesting to say the least, don't you think?
    Let it float...da Bat
    Hey Sir EdwardB,
    > I received the foam tape from McMaster & you were spot on yet again.
    > It works much better & fills the gap very well compared to the material included in the kit.
    > Thanks-O-Million!
    Hey Sir EdwardB,
    > Thanks-O-Million!
    Cool! Glad it worked for you.
    Burlington, WI
    I received the foam strip for the hood outline yesterday from McMaster-Carr. I placed the body on the car, with the help of Jeepurz, and it looks great. Completely filled the gap.
    Thanks everyone.
    Road Legal August 31, 2017
