Results 1 to 14 of 14
Thread: T5 shifter
    Northern VA
    T5 shifter
    Hi Guys,
    So the "mystery" t5 I picked up off Craigslist does not have a shifter. It proving difficult to find a stock shifter. However, there are plenty aftermarket short throw shifters out there. Does anyone use one of these aftermarket shifters? Whether it's the $40 eBay one or a $180 unit?
    Thanks!
    Senior Member Norm B's Avatar
    I bought one of the short throw shifters off eBay. Didn't end up using it for a bunch of reasons. The most important were, it is too tall in the housing area and it doesn't actually seal the top of the transmission. Also the bolt pattern didn't match FFR shifter handle. It's in a box in my garage somewhere. I'll send it to you for free if you want it.
    Norm
    Northern VA
    Thanks for the info. So what did you end up using instead?
    Here ya go. I like the $99 one listed as fitting an FFR. Note that the T handle is just for looks.
    https://www.**********accessories.co...-shifters.aspx
    http://www.factoryfiveparts.com/shifter-kit/
    I would also put a parts wanted ad here and the other forum as some people go w/ a different shifter position and may have an FFR piece sitting unused.
    Northern VA
    Craig. I am also missing the top plate that goes on the trans. My kit came with the actual shift lever
    I installed a Hurst Competition Plus short shifter, with the adjustable stops.
    No clearance issues at all, fit into the tunnel framing just fine.
    The top plate I think you mean, is actually a part of the shifter itself, not a separate part. Some RTV and the correct size machine screws, and your good t
    Northern VA
    Bill,
    Thanks for the info. I will look into that one. I am not converting to midshift, but in your picture it looks like the shifter would be pretty far back. that the case?
    Custer, SD
    PRO 5.0 here - love it! -- Chuck
    Chino Valley, Arizona
    Second vote for PRO 5.0!!
    Burlington, WI
    Quote Originally Posted by Chuck Sloggett View Post
    Chuck,
    I also have a pro5 midshifter but mine did not come with the shift handle. Did you purchase their short shifter handle?
    Jay
    Road Legal August 31, 2017
    Northern VA
    Thanks for the input guys!
    Custer, SD
    Quote Originally Posted by ThickCobra View Post
    Chuck,
    Jay
    I used the Factory Five supplied shifter lever. -- Chuck
    Quote Originally Posted by scottiec View Post
    Bill,
    I didn't use the lever pictured, I used the FFR supplied one.
    Northern VA
    Thanks!
