Hey guys,
I'm picking the engine out of its crate to assemble the clutch, flywheel and trans. When the builder put it in the crate they had all the front accessories attached. They only have two grade 8 bolts in the front left and the rear right cylinder heads for lifting. In order to get the fourth bolt in the front right, I would have to remove the accessories off the front of the engine which is going to be problematic with it still in the crate.
Is it OK to lift this engine with just the 2 grade 8 bolts they have left for me in the cylinder heads? Or should I find a way to attach 4. I know I can get 3 without an issue. Anyway, let me know...I have a 2 ton strongway lift with a chain leveler from Northern Tool.
