Results 1 to 2 of 2
Thread: Donor build wheel and tires
    Nov 2016
    Has anybody used 17x9 wheels on a donor build. What tire sizes were tried. I have 95 front spindles and hubs. 1993 lower control arms. 1995 rear end.
    Yes. Usual tire is 255 front and 275 rear. The donor LCAs may limit wheel turning. The wheel's inner edge out at the rim hits the front surface of the LCA. Either grind or sledge hammer for a little clearance.
