I need to see some pictures of the wiring harness exit out the front of the drivers foot box. I have the Mk IV Anniversary. It has holes for the clutch cable, which will not be used, for that, a brake booster mount below that, which also will not be used. I also have the big hole, outboard from the clutch cable hole, probably for the reservoir to master cylinders hoses. I have some matching white covers for the not used holes. The harness has a rubber grommet, which I can match to a hole in one of the covers. Any advise or pictures appreciated. I already have the front of the foot box mounted so it is not coming off for modification. Thanks,
