I just purchased a universal push rod, and its too long, wondering if anyone might know just hoe long it should be? thanks inadvance
I am holding in my hand a stock fox body mustang brake push rod from my '91 footbox. From back of the rod to the master cylinder push end (small end) it is very close to 6". I am now using a Willwood master cylinder with an adjustable push rod. When adjusted it measures the same length, 6". Need your application to supply any additional info, like what peddle box you are using.
