Engine Factory
Results 1 to 13 of 13
Thread: Introducing the PRO-LCDi-200 LCD Guage System!
    It's time to unveil the next product line in the LCD gauge suite - the PRO-LCDi-200! This system is
    much like it's little brother (100 series), except for the extra
    remote LCD touchscreen and
    secondary control module, hence the 200 series name.
    With the additional screen, you are able to control functions on the main LCD dash display, as well as
    view alternate gauges in real-time. Purchase the optional relay module to control lights, doors,
    and other common OEM functions.
    The remote screen has the capability to be used as an audio entertainment center toplay your favourite
    music through the audio port.
    ** Remote screen shown with optional TPMS, OBDII, and Electronic Engine Start features.
    For information on the single screen, LCDi-100, click this link:
    http://thefactoryfiveforum.com/showt...ase-amp-Promo!
    if you have already cut your gauge pod inlay/bezel, you will need to fabricate or purchase another.
    A deposit of $600 is required, and balance due upon shipment. Allow 4-6 weeks for delivery.
    Payments can be made via PayPal, Money Order, or Credit Card (soon to be established).
    Thank you again for your interest, and if you have any questions/comments after reading the PDF,
    feel free to post them here, or send me a message!
    Sincerely,
    Tino
    FedEx Shipping Estimates:
    Ontario - $25 (3 business days)
    Canada – Toronto to Victoria BC , $45 (5 business days)
    USA – Toronto to California, $100 (5 business days)
    Tablet Requirements (for user supplied tablets):
    - Touchscreen
    - USB 2.0 data transfer
    - Windows based 32/64 bit Operating System
    - Size to fit within dash pod of GTM
    - 5 VDC or 12 VDC charging port (USB or Adapter)
    Previously Uploaded Demo Video
    [B][U]PRICING INFORMATION
    Custom LCD Gauges , Data Loggers, Performance Parts
    www.procision-auto.com \\ 647-522-9953 \\ Voice & Text
    A quick demo of the Aventador skin for those that are interested. This will work with the 100 and 200
    series modules.
    There's quite a bit going on with development of the 200 series system. ODBII for CAN Bus is working (2007+ PCMs), and J1850 is just around the corner. Video to follow soon.
    I'm doing two custom projects for customers that are opening up new doors. First off, a muffler controller
    that operates a valve to control exhaust flow for performance or cruising conditions. He would like the
    LCDi system to take the place of the smart phone app.
    Second, an electronic HVAC controller to replace the Vintage Air knobs. The remote screen will have a
    graphic interface that will control fan speed, temperature, and Air Conditioning. It will also act as an
    automatic Climate Control. The interior temperature sensor will report cabin temperature to the LCDi
    module, and the module will adjust temperature and fan speed to maintain your desired temperature.
    From this:
    To something like this:
    The next step is to try this in the GTM. I'll have a video of this as well.
    Senior Member Edgeman's Avatar
    Medicine Hat, Alberta Canada
    Will this work with the Infinity Box, I can not remember if you said it would? If it does not then you need to get together with Jay Harris and have something put together. With these two products together you would have something unique. I sure wish this was around when I build my car. Having all the controls in the dash would have been great.
    GTM #370
    Car was completed and I have SOLD my car
    http://edgemansgtm.weebly.com/index.html
    Doing what you like is freedom - liking what you do is happiness
    later,
    Doug
    Yes, it will work with the Infinity Box. It can work in tandem, or as a separate stand alone module.
    The LCDi system can actually control most of what the Infinity Box does, and more. Once the BlueTooth/
    WIFI is programmed, it will have remote capability and also able to report information from the car to
    your home computer and/or smart phone.
    Obdii can bus ready for order!
    The CAN bus protocol is ready for the LCDi system with the following PID's confirmed:
    #define PID_ENGINE_LOAD 0x04
    #define PID_COOLANT_TEMP 0x05
    #define PID_SHORT_TERM_FUEL_TRIM_1 0x06
    #define PID_LONG_TERM_FUEL_TRIM_1 0x07
    #define PID_SHORT_TERM_FUEL_TRIM_2 0x08
    #define PID_LONG_TERM_FUEL_TRIM_2 0x09
    #define PID_FUEL_PRESSURE 0x0A
    #define PID_INTAKE_MAP 0x0B
    #define PID_RPM 0x0C
    #define PID_SPEED 0x0D
    #define PID_TIMING_ADVANCE 0x0E
    #define PID_INTAKE_TEMP 0x0F
    #define PID_MAF_FLOW 0x10
    #define PID_THROTTLE 0x11
    #define PID_FUEL_LEVEL 0x2F
    #define PID_BAROMETRIC 0x33
    #define PID_BATTERY_VOLTAGE
    More PID's to follow and available upon request as well. J1850 protocol should be ready next week. Here's a quick video featuring the remote touchscreen (7 x 4 inch display area):
    I had a question about the remote screen in the video above:
    The gauges are all set to Throttle Position (TPS) and that's why they all move at the same time and do not correspond to the numeric data.
    In fact, none of the gauges are connected to anything with respect to Oil Pressure, AFR, or MAP. It is simply a functional 'proof of concept'
    to check whether the CAN bus data can be shown numerically and graphically.
    Hopefully, that clears things up!
    OBDII CAN and J1850 protocols now ready to order!
    This feature has the ability to read codes and display the associated fault.
    You can clear codes as well as scan numerous PID's for engine information.
    The OBDII will be a standard feature on all LCDi kits (excluding basic versions).
    Up to 8 PID's can be logged with J1850 protocol and up to 20 PIDs can be
    logged with the CAN bus protocol.
    Examples of PIDs (if supported by your PCM):
    - Injector Pulse Width
    - 02 Sensor ratio
    - Intake Air Temp
    - Throttle Position
    - Manifold Pressure
    - Barometric Pressure
    - Ignition Timing
    - Engine Temperature
    - Short and Long Term Fuel Trim
    For a more extensive list of OBDII PID's and general info see this link:
    https://en.wikipedia.org/wiki/OBD-II_PIDs
    Note that the Expanded option price has dropped because it results in
    wiring and module development on my end. The data can be hardwired to
    the DLC harness, or you may purchased a DLC to DB-9 connector for $25
    that plugs into the vehicles existing port.
    This is an example of the display screen on the LCDi200 system. The OBDII
    data will be displayed on the main screen for the LCDi100 verions.
    LCDi200 Pricing
    Vintage Air Controller Ready to Order!
    This eliminates the mechanical knobs in favour for a graphic touchscreen.
    "AUTO" activates the automatic climate control. The system will use the internal cabin temperature sensor to
    keep the temperature at your desired set point. The controller will adjust fan speed or temperature automatically
    in order to achieve the result.
    The Air Flow diverters can be set by pressing the arrows to direct air to the main vents, foot-well, or both zones.
    Note: These features can be used with the smaller 2" x 4" touchscreen controller:
    Website updates and pricing to follow.
    Tino
    Here's the latest demo with the Electronic Engine Start and Stop as well as the Vintage Air controller.
    Don't mind that the temperature units are in Celsius - the REAL units
    A couple of photos of the 200 system at night. This shows the size of the gauge graphics on the
    main dash display using the new, larger version of the Aventador gauge.
    We have a game changer here!
    I've been evolving the design of this system to have more OEM functionality, look, and feel. The
    latest update is incorporating an embedded controller and dedicated LCD screen as opposed to
    using generic tablets.
    The new hardware addresses many issues with screen size, boot-up time, connectivity, and lower
    power consumption. It also eliminates the need to charge the tablet batteries, or use a maintenance
    charger when the car is not driven for several days.
    The controller boots up very fast and can handle up to three LCD screens at4K HD resolution. I'm
    not sure that having that much graphic capability will be cost-effective, or necessary but the processing
    power is there to make things smooth.
    Total system weight will be equal, or less.
    Power consumption will be lower as well.
    This system will now be able to compete with 'the big boys' for similar costs that I have been able
    to offer. Once I have figured out the module enclosures and any supporting circuitry I'll start a new
    thread and announce the pricing.
    Forthcoming Changes:
    1.) 9" screen main LCD screen (8.31" wide x 5.0" high)
    2.) 7" x 4" touch screen for remote control and auxiliary display
    3.) Embedded controllers
    There have been many requests for an audio MP3/Radio and backup camera have been made for
    the Remote Screen which I'll be implementing as well.
    Wow, that's quite a leap ahead in your product development. So everything will completely shut down/not need power when you turn the car off? What is the boot-up time?
    MK3.1 2004 Mach 1 donor.
    GTM #304
    It is a huge leap, but it had to be done. Tablets go out of circulation quickly and that
    really makes it difficult to maintain the system.
    With only the LCD screen to source, it makes finding replacements a piece of cake if
    needed.
    The controller will go into sleep mode (like your car's PCM) when the ignition is turned
    off. It runs on the main vehicle battery with very low power draw.
    The first initialisation when installed to the car is 21 seconds. This happens only once
    (or every time you remove the main battery cables).
    Wake-up from sleep mode when turning on ignition is instant (about one second).
    Operation is not much different than when you would expect in a production car.
