Results 1 to 17 of 17
Thread: 33 Hot Rods in DFW?
    Mar 2017
    33 Hot Rods in DFW?
    Are there any owners of the 33 Hot Rod ( prefer with a hard top ) in the DFW are that I can try to fit into?
    Mar 2017
    That doesn't list their forum user names, though.
    Oh, whoops, you're right! That doesn't seem very useful
    A question for http://thefactoryfiveforum.com/member.php?710-geoffav then - perhaps he can explain how to use it..
    I found a long-winded way to do it.. search that thread for the name you find on the map and you'll see who posted it..
    Dallas, TX
    Look up WRP, he's local, pretty near you if I remember right.
    Let me know if you touch base, I'd like to go see his car too.
    SL-C, LS3 525, Mendeola SDR5,
    Senior Member JOP33's Avatar
    Haslet, Texas
    I'm building in Haslet, but only a week in. Not sure there's much to see at this point!
    Mar 2017
    I know Haslet, my mother used to live in that area. Did you opt for the hardtop?
    Mar 2017
    I tried a user name lookup on WRP and came up empty. Hope he sees this!
    Quote Originally Posted by dallas_ View Post
    Jun 2012
    CrossRoads, Pa.
    here's a link to WRP's build thread: http://thefactoryfiveforum.com/showt...it-075-Restart
    just click on his user name and send him a private message.
    Nevin, AKA H. R. Lucky
    Mar 2017
    I found him, pm sent, thanks
    I have a 33 Ford roadster. Your head isn't going to be the problem, if it is your feet won't fit. Sent you a PM/replied.
    Mar 2017
    My feet are always a problem Replied to your PM
    Haslet, Texas
    Quote Originally Posted by Mick_d View Post
    Yes, I did. Just now installing rear brakes...http://thefactoryfiveforum.com/showt...Mobile-1-Build
    Senior Member TDSapp's Avatar
    Frisco, TX
    So Mick_D what part of DFW are you in?
    Tim
    Mar 2017
    I'm in North Carrollton, just between The Colony and Lewisville, south of 121. Where are you?
    Frisco, TX
    I live in West Frisco and am just north of The Colony. My stage 1 Hot Rod gets delivered next month, you are welcome to drop by and check it all out once it gets here.
    Tim
