Page 4 of 5 FirstFirst ... 2345 LastLast
Results 121 to 160 of 199
Thread: FFR's own 818R
  1. #121
    Ahhhh, I'm starting to recall a bit..... when he went down, he didn't go down FROM stock, he went back TO stock right? IE stock is 10mm, he originally had an 11mm on it, then went back to 10mm?
    I'm 95% confident I went from 11mm to 10mm. I'll have to check my old thread.
    EDIT: Yes went from 11mm to 10mm.
    "I want to think it was the 10cm oil pump. I think the 11cm oil pump was bypassing so much oil because of its higher flow volume. The oil was bypassing all the time with the 11cm, just spinning in the block heating up. I also read the 11cm is for journal bearing turbos- I have a ball bearing- that maybe part of it with the oil restrictor for the ball bearing turbo you put on????)
    I also do not think you should not have a closed vacuum block with the Element Dry Sump. The vacuum is working against the scavenge, I know Gator has his working though, but both ARE and Element told me to vent it like I have.
    I ran without the flat bottom aluminum piece under the engine. That could of helped cool everything also. I did not notice any handling issues running without it. I may suggest the new owner throw it on and try it."
    Thanks- Chad
  2. #122
    I ran every single run with the aluminum piece under the engine. No oil heating problems whatsoever. As I've said, my issue is actually oil not coming up to temperature. Going with only the single cooler in the back (ducted and with a fan) when my engine goes back together. I am keeping the front coolers installed, but not plumbed, just in case.....
  3. #123
    Bumping this up for a big weekend for FFR. Good luck!
  4. #124
    Keeping my fingers crossed you can get a clean fast run in without mechanical issues.
  5. #125
    Hmmm. Finger-crossed the Curse is lifted, but unfortunately on paper it looks like some darn issues maybe arrose... Grrrrrrrrr.
    https://racehero.io/events/nasa-ma-h...lts/1073742769
    https://racehero.io/events/nasa-ma-h...lts/1073742770
    Thanks- Chad
  6. #126
    USA
    The guy running 1:45 got disqualified as well. I'm guessing noise. (Complete guess, I don't get their till tomorrow).
    Previous forum name was "Fezzek"
  7. #127
    DQ for spin in the second session
    https://racehero.io/events/nasa-ma-h...lts/1073742771
    They all look better in the most recent session
  8. #128
    2:02- not bad in this session. Thumbs up! https://racehero.io/events/nasa-ma-h...lts/1073742771
    Thanks- Chad
  9. #129
    Webmaster, FFR
    Middleboro, MA
    Wayne Presley nailed it! 1:59.9 in the last race!
    What a professional. Each go out he ran faster:
    Practice - 2:11.005
    Race 1 - 2:05.224
    Race 2: 2:02.528
    Race 3: 1:59.900
    Very hot conditions made tires greasy. Wayne feels the car has more in her!
    Dave Lindsey
    FFR's Mad Dog
  10. #130
    Denver, CO
    Quote Originally Posted by Mad Dog View Post
    Practice - 2:11.005
    Race 1 - 2:05.224
    Race 2: 2:02.528
    Race 3: 1:59.900
    Awesome! Thanks for updates.
  11. #131
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    The day went well and the car hauled A$$, topping 157 mph on the straights. I had a good day in the car that started with a hiccup with the ball on the bottom of the shifter breaking off just as I was taking the green flag in the warm up session. We pulled a part off the the Koni 818C and got the car ready for the next session. John George's car, Trevor's and the 818R all had Rackpak data systems on them so we were able to overlay the data. We figured out that I was losing most of my time against John in the high speed esses and up to the Oak Tree corner. I put that data to use in the last session and layed down the 1:59 lap time on the first lap before the tires got greasy. I did a cool down lap and gave it another shot but missed an upshift in the esses and had to abort that lap. Not enough time to cool the tires before the session was over so I pulled in. Really great time and could not have done it with the assistance of John George, Jim Schenk, and Mark Dougherty today. I'm tired and happy and off to bed. Will upload videos in a day or so
  12. #132
    Denver, CO
    Awesome Wayne! Thank you for getting the 818 out there​.
  13. #133
    FFR Looks like they're having a great showing at the event!
    Great job Wayne!
  14. #134
    Bowling Green, KY
    Nice work Wayne
  15. #135
    Administrator
    Enterprise Alabama
    Here's a quick video of the second round showing the rear view. The green car is a 2015 Viper ACR, gives you an idea on how hard this car accelerates
  16. #136
    Edmonton, Alberta
    Wow that pulls hard, thanks for sharing! Looks like a fast course!
    Adam __________________ Instagram @brap818
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    My widebody 13b-REW powered build thread
  17. #137
    Administrator
    Enterprise Alabama
    Here is the fastest lap
  18. #138
    Bowling Green, KY
    Impressive job Wayne.
  19. #139
    Wow very impressive cars flying!!!
  20. #140
    Mar 2015
    Houston, Tx
    Son-of-a ***** that was fast!
  21. #141
    Hell of a drive! Nice job
  22. #142
    1:59 is awesome!
    Owner: Colonel Red Racing
    818R ICSCC SPM and HPDE Rental at Oregon Raceway Park
    2005 Subaru STI Race Car ICSCC ST and SPM, NASA ST3
    Palatov DP4 - ICSCC & SCCA Sports Racer and HPDE Rental at Oregon Raceway Park
    Race Videos at www.facebook.com/ColRedRacing
  23. #143
    Administrator
    Enterprise Alabama
    Thanks Mitch, I saw you had your car out this weekend too.
    Quote Originally Posted by redfogo View Post
    Wasn't ever airborne
    Quote Originally Posted by wirenut View Post
    Quote Originally Posted by mikeb75 View Post
    1:59 is awesome!
    I was happy but I left about 2-3 seconds on the table. Next time I'll be fast!
  24. #144
    Apr 2015
    Andover, MA
    That must frustrate the heck out of them! Nice driving.
  25. #145
    Fayetteville WV
    Wayne,
    Super car!! That thing hauls a$$. Nice job driving. Over 150 is amazing.
    Thanks!!
    Len
    1972 Corvette Stingray 350 c.i. Manual Steering & Brakes
    2003 H-D Softail Deuce 88 c.i. TwinCam
    Gen 3 Coupe Dreamer
  26. #146
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    How do you like the brakes Wayne? It seemed like the area the Viper was making (instead of losing) ground on you was in the braking zones, but it's hard to tell from the video.
  27. #147
    It looks like tire smoke in the braking zones? Maybe too much rear bias?
    818R Build date 10/31/15
  28. #148
    Administrator
    Enterprise Alabama
    That was the out lap and not warm tires, he just wanted to press it harder on cold tires than I did.
    Quote Originally Posted by DanielsDM View Post
    The smoke was tire rub, the brakes were awsome. Pulled 2 G's under braking.
  29. #149
    Wayne, what size wheel / tire package are your running?
    MK3.1 Roadster completed 2011
    818R built with EZ36R H6
  30. #150
    Wow, that was fast! I can't believe the speeds you were carrying through the uphill esses. Nice job!
  31. #151
    Administrator
    Enterprise Alabama
    225/40/17 and 255/35/18 Hoosier A7's on 17x9 and 18x9.5" wheels
  32. #152
    Wayne
    great job out there this weekend.
    You really picked it up quick.
    great car prep also.
    You did an amazing job. and I had a blast hanging with you.
    cant wait for the next time.
    The traveling Builder
    717-773-5624
  33. #153
    Wayne, were you getting tire rub in the front, rear or both? And where do they rub?
  34. #154
    Administrator
    Enterprise Alabama
    Just in the front and the outer lip. Rubbing only under max braking or hitting the curbs.
  35. #155
    How was the oil temp? Nice driving!
    Thanks- Chad
  36. #156
    Bowling Green, KY
    I recall when testing Wayne said he saw 260-270 when really pushing the car, which isn't surprising IMO with the power/boost the car is putting out and running the car to 7500+. I don't recall what FFR has on that car for an oil cooler but would think with the short qualifying type runs the temps wouldn't be too bad. My car with 100+ less hp and the OEM cooler/heater on a 90+ day I will see 225-230 after a 30 minute session. Horse power is heat.
  37. #157
    Last question about the wheel tire package, I promise. What offsets are you running in the front and rear?
  38. #158
    That's the kind of video that gets me motivated to build one of these cars. Just picked up a donor car. Now I'm working on funding for a kit. Maybe I missed it, but I assume since the car has a 6 speed in it, it has a limited slip diff? Out of curiosity, what year car is the transmission out of?
  39. #159
    Administrator
    Enterprise Alabama
    260 max after 5 laps
    I'll check tomorrow
    Quote Originally Posted by Scrmblr2 View Post
    It has an 06 STI with a RallySpec 5th and 6th gear.
  40. #160
    Administrator
    Enterprise Alabama
    All the wheels are +42mm offset
Lodestone Billetworks
