Results 81 to 120 of 207
Thread: FFR's own 818R
    Fayetteville WV
    It's on a Friday...
    Hi Wayne,
    I'm not to far from VIR. What is the date? I can get a Friday off pretty easy>
    Len
    1972 Corvette Stingray 350 c.i. Manual Steering & Brakes
    2003 H-D Softail Deuce 88 c.i. TwinCam
    Gen 3 Coupe Dreamer
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    May 19th with a FFR car corral on Saturday the 20th
    Fayetteville WV
    Wayne,
    I'll to get off and slide down the VIR. It would be fun to catch some grassroots racing. If it looks like I can get there, I'll try to look you up. Maybe you could use an extra gofer. Thanks for the info. Best of luck!
    Len
    Gen 3 Coupe Dreamer
    Administrator
    Enterprise Alabama
    Well test day 2 is in the books. Added an oil cooler, reducted the intercooler, and put on a fresh set of hoosier A7 and test ended up pretty well. Man the A7's hook up over the old Yokohamas...
    Clovis, Ca
    Hoosier R7's = Crack
    Hoosier A7's = Crack, Meth, Opioids, In-n-Out, Lofthouse Sugar cookies.
    Thanks- Chad
    Sgt.Gator's Avatar
    Bend, Oregon
    Wayne is it fair to say that turbo lag with the FMIC is not an issue? Thoughts on that?
    Owner: Colonel Red Racing
    818R ICSCC SPM
  7. #87
    Senior Member metros's Avatar
    NoVA
    Any video from testing day 2 would be happily reviewed
  8. #88
    Administrator
    Enterprise Alabama
    Quote Originally Posted by metros View Post
    Patience.... it takes time to drove home, lay the video and data together and the upload
  9. #89
    NoVA
    Excited!
  10. #90
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    To tide you over.......
    https://youtu.be/quQyp9AENss
    Fixed it for you Jeff....Wayne
  11. #91
    Sgt.Gator's Avatar
    Bend, Oregon
    Not sure why my youtube video isn't embedding... Anyone know? I click the "insert video" button, paste the youtube URL in, and all I get is the link above.
    I had the same problem in another forum, you have to manually take the s out of https.
    818R ICSCC SPM
  12. #92
    Administrator
    Enterprise Alabama
    (video=youtube;quQyp9AENss)https://youtu.be/quQyp9AENss(/video) is the text line you need to embed that video. Replace the parentheses with brackets to make it work
  13. #93
    Hindsight's Avatar
    Atlanta
    Thanks Wayne and Gator!
  14. #94
    Apr 2015
    Andover, MA
    that looks and sounds awesome. I like how the first 3 passes down the straight get progressively faster! nice.
  15. #95
    Administrator
    Enterprise Alabama
    Quote Originally Posted by ben1272 View Post
    The first 2 laps are under yellow but that third lap I was moving pretty fast by start finish.
    https://youtu.be/QDf9-ISUJH0
    Here's another video. I was having to lift just past start finish to keep from going over the sound limit at the sound check station.
  16. #96
    Reno, NV
    Wayne,
    That looks like a lot of fun, you were moving!
    What does that car have for a muffler? What is the sound limit at RRR?
    818R Build date 10/31/15
  17. #97
    Administrator
    Enterprise Alabama
    Sound limit was 104 and I did 106 with no muffler
  18. #98
    Wayne,
    Car look and runs fast. Great job building and driving.
    Is the FP gauge on the left of the screen Fuel Pressure? Why is it bouncing between 30 and 70?
  19. #99
    Reno, NV
    Thanks Wayne. Looks like I will have to put some sort of muffler on mine. Thought maybe the turbo would muffle it enough to keep it under 103db, guess not.
  20. #100
    Administrator
    Enterprise Alabama
    Wayne,
    Because the fuel pressure is referenced to manifold pressure
    Quote Originally Posted by DanielsDM View Post
    I was 108 dB one pass but the mic was not 50 ft from the track either.
  21. #101
    Thanks Wayne,
    I didn't know FPR's worked like that.
  22. #102
    Bowling Green, KY
    I was 102db here at NCM before I installed a small racing muffler with my JDM twin scroll set up, I am now 97ish on a 3rd gear pull around 6900.
  23. #103
    Administrator
    Enterprise Alabama
    Thanks Wayne,
    The FPR maintains the same pressure differential across injector so the ratio of pulse width vs fuel flow remains constant. So when the manifold pressure goes down so does the fuel pressure. Conversly when the motor is making 22 psi of boost the fuel pressure goes up to 65 psi.
    I gotta make a new exhaust for this car anyway so a small muffler it's going to get
  24. #104
    Administrator
    Enterprise Alabama
    https://youtu.be/Bn7_WOYD99A
    1st session before I was black flagged for sound
  25. #105
    Leesburg, VA
    Was the oil getting a bit hot at the end? It seemed to climb steadily.
    Great video btw, it's fun to watch it pass everything on the track.
  26. #106
    Administrator
    Enterprise Alabama
    I would have been passing more but it was pass by point by only.
  27. #107
    Nov 2012
    I hope you don't run into the FFR curse that has hampered all the other 818 attempts at the GRM UTCC.
  28. #108
    Okinawa, Japan
    I can't get there until Saturday, but SUPER excited to visit with the fam. Good luck Friday!
    FFR Build Status: Reset button hit
    '03 Subaru Impreza eSi RHD...because Japan
  29. #109
    Atlanta, USA
    That looks like the other cars were in reverse.
    Looking forward to seeing this at VIR.
    Martin
    Previous forum name was "Fezzek"
  30. #110
    Senior Member Rob T's Avatar
    Woodruff, SC
    Wayne: Can you remind me again where you ended up with oil cooling? After my cam shaft seizure, and the fact that I couldn't get my oil above 190F on a 104F day, I am thinking of going with only the back Setrab cooler with a fan and vents ported to the side scoops. I am going to be somewhere around 325-350 HP. Dry sump and minimum of 5 quarts in the reservoir. Chad installed front coolers, and I am planning on leaving them in, but plumbing around them for now. BTW. Your car was awesome on the track. I admire your skill. Rob
  31. #111
    Clovis, Ca
    I pulled off/let off when the oil got to 240. I see 260+ on the new video when you really push it after a short time. Do you plan on doing more to cool it? Once I went to the different oil pump, it fixed my oil temp issue. I should have done that first instead of adding 3 coolers....
    Rob- The rear one should be fine now, if not just connect one at a time. You should not need to make any oil lines if I remember correctly. I did them in a series, so I think I just added on with adapters.
    Thanks- Chad
  32. #112
    Denver, CO
    I have been away for a little while and now I read this thread after seeing the latest FFR update email. This is awesome! I am so glad to see FFR getting back to the races. It will be great to see what the car can do!
  33. #113
    Hindsight's Avatar
    Atlanta
    Chad, which oil pump did you switch to? I wonder why it helped the cooling? Maybe by increasing the amount of flow?
  34. #114
    Administrator
    Enterprise Alabama
    He went down on oil pump size to reduce the heating from over pumping
  35. #115
    Hindsight's Avatar
    Atlanta
    Ahhhh, I'm starting to recall a bit..... when he went down, he didn't go down FROM stock, he went back TO stock right? IE stock is 10mm, he originally had an 11mm on it, then went back to 10mm?
  36. #116
    Administrator
    Enterprise Alabama
    I think it had a 12 in it to start with and then he went back to the 10mm
  37. #117
    Hindsight's Avatar
    Atlanta
    Got it ok thanks. Good to know, for when and if I upgrade my engine.
  38. #118
    Looking good on the track!
    Curious on the make and weight of oil your running in the engine?
    Hate to cause a heated debate, as everybody is running the best oil right?
  39. #119
    Bowling Green, KY
    I am using Mobil 1 Racing 0-50 in my R.
  40. #120
    Administrator
    Enterprise Alabama
    I'm using 20w-50 Royal Purple XPR
