Results 1 to 7 of 7
Thread: Ignorant paint question
    Senior Member 3yearplan's Avatar
    Dearborn Heights, MI
    I don't want to do bright and shiny. I like the satin look. Is the finish still smooth, like a clear coat is applied? If so how does in not make the paint shiny? Sorry for a dumb question that will probably only appeal to 1% of us.
    Thanks in advance, Mike.
    Mark IV 7923 arrived 11-14-12
    DOHC 4.6L, Tremec 3650, 3 Link 8.8 w/3.73
    Catonsville, Maryland
    Mike,
    Not a dumb question. The finish should still be smooth, the clear coat usually has a flattening agent added to it, to kill the gloss. How much is added will depend on how much gloss is lost.
    Ron
    Mar 2014
    Michigan
    +1 on what Ron said. It should still be smooth, you just use a different clear coat to achieve a matte appearance.
    Thanks guys, that is just the bit of information I was looking for.
    On my 33 my painter used satin clear coat. Still looked great but I could wax the car. Not the case if you go with flat paint.
    As an experiment get a can of can of this;
    http://www.minwax.com/wood-products/...-spar-urethane
    and one of this
    http://www.minwax.com/wood-products/...spar-urethane/
    Spray 3 coats of each on something smooth. Of course you don't get to choose the exact level of satin but you will get the idea.
    wallace18 that's the direction I'm hoping to go. Do you have a picture ? CraigS, thanks for that tip, definitely worth trying.
