Thanks Thanks:  84
Likes Likes:  608
Page 21 of 22 FirstFirst ... 1119202122 LastLast
Results 801 to 840 of 867
Thread: Roadracer's #997 build
  1. #801
    Jul 2020
    Spencer, MA
    Bummer dude! Glad no personal injury. Can you look at the footage frame by frame to see what it might have been?
  2. Likes RoadRacer liked this post
  3. #802
    Some people have tried.. seems most likely it’s a big tire fragment from the Semi that’s parked a 1/4mile down the road..
  4. #803
    Sep 2022
    Huntington, IN
    That's exactly what it looks like to me.. we call them Road Gators
  5. #804
    Ok, I'm baaaaaack!
    After my recent "adventure" I was lucky enough to score a complete Deluxe setup (aka "32" grill and radiator) from Frank, who was so on the ball that I swear he was already at the UPS store the next day when I said "hell yeah". Kudos to "Just 1 more" for helping me out.
    My smashed radiator was a stock FFR 33 setup with an Ebay radiator and some aluminum bracketry I made to fit, so I knew there was going to be some fabrication required, even though this was a deluxe kit. I have a Gen 1 first of all (the deluxe wasn't an option) so I assume the brackets are different nowadays. Secondly, more importantly, I have my radiator tipped back at 19º to match the side panel body line and make it more swoopy.
    I got the package from UPS on Wednesday and had some shopping to do. First, there's only one bung in the bottom of the radiator (my old one had 3!) so I have to use that for temp sensor.. but it was smaller 1/4npt so I had to order that. Second, there's NO RADIATOR CAP! wth? So I ordered an inline Moroso one to put in the top hose for now (you'll see why).
    In the meantime I started mocking it all up. Didn't take much to modify the brackets to fit, chopped some off, laid them over a bit. Mocked up the 19º slope and it all started to look pretty nice.. and then I noticed that because the radiator is like a foot shorter than the old one, the bottom hose goes straight into the chassis. At least where I have it placed, and sloped, the hose goes RIGHT where the horns are bolted to the chassis plate that joins the rear of the LCA bolts.
    Right here:
    Moving the horns was easy, I moved them to the front of the chassis, below the radiator, but still behind the shell. But the chassis wasn't going anywhere, so.. I cut it out. ¯\_(ツ)_/¯
    The plate is welded all around the main chassis, so I figured that part was superfluous so I waved it goodbye. The radiator hose fit nicely through the gap left there.
    Here we are, all better.
    This is the only part I don't like.. for obvious reasons. Looks like a** and annoying that you can't effectively bleed it. So next month when I'm installing my new motor I'll get a cap welded to the top of the radiator. But surprisingly, this works well enough.
    I removed the temp sensor from the block, then filled the radiator until the motor was full, then put the sensor back in. Then filled rad as much as I could and threw the hose on. There's going to be air in there but I've run it through 4 full heat cycles (thermostat open, hot enough for fan to come on, etc) and a "spirited drive" that this will be good enough for the race next weekend.
    Oh.. I did find more damage from the semi-tire. It had hit the front lower bodywork just in front of the door. Nothing visible but I noticed the door sounded different today. Just more rattly. When I looked, all these rivets were sheared! They look normal, but none were attached to chassis.
    For some strength, I replaced them with a strip of aluminum.
  6. Thanks Just 1 More thanked for this post
    Likes Just 1 More, JimLev, Mastertech5 liked this post
  7. #805
    So far all I know: built to rev higher than stock, don’t remember what was said though.. but likely 6500 vs 5500.
    The heads are AFR 210. Runs pump gas (9.5 to 1). Hydraulic roller cam 555 lift. Wisco pistons and steel crank and rods.
    Btw, I talked more with the guy who built this motor - he said that the cam runs out at 6800, but the motor is built to 7500. LOL
  8. #806
    My fastest run today - everything was working great. Could always do with one more run of course - but today we were cut to 4 instead of 5 without warning!
    My gopro 12 quality is incredible if you compare to my dashcam that I normally use. duh! The image stabilization and 4k quality is amazing.
  9. Likes Ltfracing, JimLev, Mastertech5, JOP33 liked this post
  10. #807
    Sep 2022
    Huntington, IN
    That's awesome James, looked like a tight course
  11. Likes RoadRacer liked this post
  12. #808
    Sep 2022
    Huntington, IN
    James, Have you been playing with the QA1 compression and rebound settings? Curious where you've settled at?
  13. #809
    James, Have you been laying with the QA1 compression and rebound settings? Curious where you've settled at?
    I haven’t yet. I did some initial setting up and then we had a winter break with no racing. Then the accident and now only two weeks until the new engine and the next race only a week after that! I suspect I’m not going to be focused on them for a while.
    Having said that, I’m very happy with the setup right now.
    Here are my current settings though:
    Front: c2 r4
    Rear: c3 r5
  14. Likes Just 1 More liked this post
  15. #810
    New Motor
    Now I'm back and recovered from my marathon motor swap trip, it's time to post about it here!
    We left Austin on Tuesday with the car on a rented trailer, for a 16hr drive to Atlanta. It was a long day, we left at 3:30am!
    Wednesday morning we headed out to the shop. First job was to remove the motor from the 55 chevy it has been in since the early nineties. They've modified the intakes over the years, even with a blower at one point, but the motor hasn't been out of the car for 30 years. The motor bottom end was properly built with steel crank, pink rods, AFR heads - no need to touch any of that. Cam runs out at 6800, but engine can rev to 7500. (I later set my shift light at 6400, but no rev limiter)
    It took us all day to disconnect and remove the motor - slower than we expected! But by end of the first day it was on the engine stand.
    We took a trip to the local Summit Racing that evening and bought a bunch of parts. We reused my intake and carb, but had to buy a new oil pan, noisy gear drive (something I've always wanted) and a new 3.73 gear set (changed from my stock 3.27). Plus gaskets and some misc. Total was ~$1,000.
  16. #811
    Day 2..
    My first job was to remove my motor, while my friend worked on the new one, removing oil pan, swapping gear drive, cleaning up.
    You can see the original builder's name written on the crank from 30 years ago - the current owner's brother Alex. Also the "pink" rods.
    This second day was just as long and hard - we thought removing from my car would be easier with all the access, but it wasn't! We removed with the transmission attached and the tight tunnel made it tricky. But we got there!
    End of day two we had the new motor buttoned up with my intake, carb, new oil pan and transmission attached. The clutch showed virtually no wear btw. This pic is the closest I have to end of day 2:
  17. Likes JimLev, Just 1 More, Jeff33Ford, Ltfracing liked this post
  18. #812
    Day 3, the last day.
    We had an assembled motor, so put it into the car. This part was easy.. by then we'd learned how best to do it, took under an hour to get it back in.
    Then it was adding radiator back, re-plumbing everything, timing, headers, etc etc. I experimented with a few alternator brackets but ended up with the factory header setup.. rock solid and easy. Got a 15555 belt, but have a 15557 on order for some extra wiggle.
    Filled with PennGrade 10w40 green oil, added NGK R5671A-7 plugs at 50". Fired right up! Noisy as hell.. perfect! I've never had a SBC that can rev to 7500, let me tell you it is quite something. Changes the way you drive, and that gear drive whine.. wow.
    The motor is a beast. I don't know what you guys with 500+ hp think, but this 400-430hp motor built to rev like this is kinda insane.
    There were two problems though.
    1. I melted the electric fan.. literally. I tie-wrapped a wire to the fan cover, and although I spin-tested it, somehow the tie wrap moved to a position where the fan stopped. We smelled "something bad," but it took a minute to track it down. The fan and wiring were (literally) toast by then. Put in a new one!
    2. This next one took longer and wasn't fixed until I got home after another 16hr drive on Saturday. The passenger side of the motor was covered in a fine mist of oil. Dripping from everywhere. Even the windshield had so much oil on it I couldn't see through it. Easy, right? Nope. I could not find the leak. Even the SHOCK was covered in oil.. how? That's a foot in front of the motor! In hindsight it makes sense, but took us a while. A racing friend from the local autocross club suggested something that made no sense to me. "Put a bolt in the top mounting hole on front of the engine". That was a blank hole for the 55 engine mount, now not used. But guess what.. the motor was issuing a very fine high-pressure mist from that "blank hole" above 4000 rpm. You'd never see it. Added a bolt, and DONE!
  19. Likes JimLev, Just 1 More, Jeff33Ford, Ltfracing liked this post
  20. #813
    So with the rear ratio of 3.73 and the more hp (probably up from 250-270 to 400-430, pretty significant jump) AND revs up from 5200 to ~7000 - it's a very different car. At idle (now at ~1050rpm) it sounds evil.
    When driving, it feels like the difference between a 9mm and a 12 gauge slug.
    I can't wait to race it on Saturday - my next autocross.
  21. Likes Just 1 More, Ltfracing, sread liked this post
  22. #814
    Grand Rapids, MI
    James,
    Glad it's working out and coming together. Should be great fun.
    Yup, there's just something special about 7,000. I shouldn't but...
    Jim
  23. Likes RoadRacer liked this post
  24. #815
  25. Likes wrp liked this post
  26. #816
    Sep 2022
    Huntington, IN
    Seems we have very similar setups, i'm 401hp with a 3:73 gears. Except mines a 700R4 w/3500 stall. I'm looking forward to see how the new horses work with your driving skills.
    Congrats on the upgrade, this sure is a fun hobby
  27. Likes RoadRacer liked this post
  28. #817
    Jun 2020
    SoDak
    Great story Jim, 3 day marathon is right, all exciting but I'm sure tiring too.
    I'm sure it will be a blast to drive but squirely too, so obviously be careful
    Jim
  29. Likes RoadRacer liked this post
  30. #818
  31. Likes JimLev, Just 1 More liked this post
  32. #819
    Sep 2022
    Huntington, IN
    SO how's the new engine feeling?
  33. #820
    Grand Rapids, MI
    Nice run, looked smooth & fast.
    How's the new motor? Meeting expectations?
    Jim
  34. #821
    The new motor is fast! Ironically I was quite slow at the race as I had no idea how the car would run so was quite tentative and only running about 70%.
  35. #822
    I missed #3 even being in Australia for a few weeks, but event #4 was quite something - it was 150 miles away at Beeville, which is where they do the Texas Mile event I believe - an absolutely massive abandoned airfield that used to house B24-B29's (again, so I'm told). The runways were enormous - perhaps 100m wide? This course used an area where two runways crossed, and times ranged from 70sec (ridiculous race cars) to 120sec (novices). It was a looooong course to remember!
    I had a lot of fun using the new power and rev range. The drive there and back was almost equally fun - 300 miles in a car that seems to spit flames nowadays.
  36. Likes Just 1 More, Ltfracing, TxMike64, sread liked this post
  37. #823
    Steering.. again.
    So we've had a few threads on steering improvements, and many of us have tried a few different options. Well, I went through it again, this time with the full expectation that I was going to do something radical. Spoiler alert - it didn't work out that way
    I started out thinking; I can make my steering go straight to the rack. Maybe two joints! I was quite convinced, but the longer you look at it, the more you realize that you just can't. It's SO CLOSE, though. I was going to rotate the rack so the spline pointed up by adding a wedge spacer. Then I placed a rod as below.
    I also tried a different way - behind the headers and straight through the firewall. They were close, and if I'd done this when building the car maybe you could tweak enough to make it work, but not in a built car.
    I was quite disappointed!
    So I went back to basics, what am I trying to fix? The answer - continually loosening joints. I've been through this cycle a few times. You start off with tight joints, and after 6-12 months the slop is back. The steering wheel moves up to an inch before anything happens at the rack.
    I've seen a few theories, but digging in myself I didn't want to use other folks' assumptions. I wanted to find the slop. I measured the rotation at the wheel. Then I clamped on a piece of aluminum to the d-bar just before and after each joint, all the way through to the rack. The aluminum bar was the steering wheel radius. I measured the movement at each point, to pinpoint exactly where the movement changed.
    I found two things.
    The first was that the rack spline joint at the very end was again sloppy. The splines (on the joint) just get worn out by the hardened rack spline. But these are $30 joints so my practical and very simple solution - just replace that last joint once a year! I replaced my joint overnight from amazon. Done - and that was half the slop. Let's not fight it - treat it as a maintenance item.
    Secondly, as I measured the slop, it was not the FFR joints themselves that had the movement, it was the D-bar-to-joint interface. This was very surprising to me - I assumed the UJ part of the joint was wearing out - not the case. The d-bar was rotating inside the joint, and the grub screw did nothing to stop it. In other words, if you clamped the joint you can feel the d-bar moving inside it.
    My solution took some time, but bear with me because it really worked.
    I removed the d-bars, all of them, and drilled straight through them, and tapped them. I got longer screws and replaced the grub screws with longer version that went into the d-bar, and held them tight. This changed the feel more than anything I've done before. It's some work to tap those d-bars, but so far so good.
    As always, I'll report back in 6 months and tell you if this works long-term over many road/race miles and bumpy roads. Only time will tell. For now I have close to zero slop, and it changes the driving experience.
  38. Thanks Just 1 More thanked for this post
    Likes Ltfracing, JimLev, Just 1 More liked this post
  39. #824
    Sep 2022
    Huntington, IN
    Steering.. again.
    I've thought about drilling straight through and putting a bolt all the way through with a lock nut on the other side
  40. #825
    That was my first thought - much easier. But it wouldn't work as well - the bolt would not be able to clamp the d-bar in place. It would stop some motion for sure, but the threaded version pulls the d-bar hard against the side of the joint. If you exaggerate the problem, think of the d-bar swimming in a much larger tube, you'll see what I mean
  41. #826
    Sep 2022
    Huntington, IN
    Makes sense, thanks
  42. #827
    Mar 2021
    SE WI Kettle Moraine
    Faced with configuring steering components, I see OEMs use spline shafts and pinch bolt (female) coupling. I have used that configuration exclusively in RWD and mid-engine and I never have steering shaft loosening issues.
    I have seen D-shaft applications for crash-collapse but the engagement surface area is greater than the couplings you have documented. I assume you acknowledge that drilling the shaft reduces cross section and creates a stress riser.
    jim
  43. #828
    jim
    haha, absolutely!
  44. #829
    Weird issue with my speedo.. I plan on calling autometer hotline tomorrow.
    The pigtail was yanked out of the transmission sensor when the engine was pulled. We missed one wire to disconnect!
    So yesterday I put in the new pigtail.. and there’s no signal getting to the Speedo. When I’m in calibration mode the number stays at zero when the rear wheels are in motion.
    So I pulled the sensor out but it doesn’t look broken in any way. It could be but looks perfectly normal. So I went behind the dash and the ground is grounded and the feed wire voltage does change between stationary and moving. And the pigtail is similarly grounded on one wire (the grey).
    This all worked before so I guess that the sensor didn’t like being yanked on and broken somehow subtly inside? Yet it generates a voltage signal. Now whether it’s the right one I don’t know. I’m just testing this with a standard 12v dc meter.
  45. #830
    Oh and I did run a brand new temporary wire for the signal from pigtail to dash.. no difference
  46. #831
    Sep 2022
    Huntington, IN
    I know this probably doesn't help but, I eliminated and chance of a trans sender and went with the Autometer GPS module. Works great https://www.autometer.com/universal-...B&gclsrc=aw.ds
  47. Thanks RoadRacer thanked for this post
  48. #832
    That’s not a terrible idea.. but whenever I put my 18” race tires on to drive to an event I have to ignore the speedo anyway
  49. #833
    Sep 2022
    Huntington, IN
    That was my other reasoning, won't matter what tire size I have , it'll always be accurate
  50. #834
    I bought a stock GM sender from the local parts store, looks identical. I fitted it tonight and it worked perfectly. Comparing the old to the new, it was twisted 20deg so must have been broken inside.
    Calibrating was interesting though - it was outputting twice the signal than the old one - it used be ~43000 per 2 mile, this new one is ~86000.
  51. Likes Just 1 More liked this post
  52. #835
    Kingsland, TX
    James, how often would you say you are using your heater? If you were to built again would you still install the heater?
  53. #836
    I have never used it.. ever. Didn’t even finish wiring the switch. With this new engine I didn’t even plumb the water line back in.
    So, no, completely pointless. And I drive without windows in the winter.. just wear a coat!
  54. Thanks TxMike64 thanked for this post
  55. #837
    My latest autocross at COTA this weekend was both a failure and a triumph Well, not really a failure but my first run was really hard to control, like my car would NOT stop wanting to spin, finally taking out 3 cones and me sheepishly crawling back to the grid. I crawled all over the car trying to see what had broken, only to finally discover that I'd pulled the handbrake on in grid, and kept it on throughout the whole first run.
    I rarely use the handbrake, usually just stick it in first. But the grid was on a slight slope and I wanted to warm the engine, so..
    So that was run 1:
    Then I had a couple of better runs, a 41.7 and a 41.2, but you know.. meh. Fun and all, but slow. The car was fast on the straights, but couldn't make the turns. Look how wide I was on one of these runs:
  56. Likes Just 1 More liked this post
  57. #838
    But then I had an "ah-ha" moment and realized that my new motor (50% more power, another 2000rpm redline) was simply getting me to the corners too fast to coast around. Sounds dumb I know, but with the old engine I could go around the corners as fast as I could get to them. Now I'm relearning the car, and have to brake much more into each corner. So on the last run I tried that. Hard acceleration followed by hard braking.. and I went from 41.2 to 39.9, which as you can imagine is a huge improvement. It felt slower, more relaxed, but was WAY quicker.
    I've been about 85% of top pax for over a year, but with this run I jumped up to 91% of top pax - a massive improvement against the field. I'm pretty stoked, but cannot wait until the next event. We only got 4 runs this meet.
  58. Likes Just 1 More, TxMike64 liked this post
  59. #839
    Sep 2022
    Huntington, IN
    Hopefully you can laugh about it now.. lol
  60. Likes RoadRacer liked this post
  61. #840
    Oh I was laughing as soon as I saw it. The folks around me in grid loved it too
  62. Likes Just 1 More liked this post
