Mustang Gauges to new Factory 5 Digital
I am converting my MKIII gauges from the original Mustang GT 1998 Donor White Pod and cut gauges to the new Digital Factory 5 Set. I am not an electrician, and I need detail help on how to migrate from the Pod to the Gauges. there are two main harness connectors to the White Pod. does any one have detail wiring instruction, or could tell me where I can get photos or color wiring diagrams or anything..... I am stock and need help.
I can't help you with your donor gauges or wiring harness. But the gauges do come with instructions. In simplest terms, each gauge needs +12V ignition source (on when the ignition is on), ground, +12V from lighting circuit, and the sender wires where applicable. Each of these needs to be identified from the donor gauges you remove. Should be easy enough with a voltmeter.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
Thanks ed, its a start. just don't want to short wire......
