I built my E-Brake mechanism today and unless I'm not seeing something the anchor bolt is too short. Attached pictures show ratchet fully engaged in the teeth and at best I can only attach the button 2 turns.
Not enough to release the ratchet from the teeth. My only though is that the button should enter the handle however the button is much larger than the hole in the handle.
Anyone else run into this or have suggestions?
