Got the PCM mounting bracket from FFR. Checked Edwardb and WareagleScott's logs AND the manual (what a concept!). Got a pretty good idea where it's supposed to go. BUT... it doesn't seem to fit. check out the photos:
and
You'll note that where I have it positioned that if I line up the top of the bracket with the frame, the bottom isn't even close. Same holds for the other way. Line up the bottom and the top is off. So, one of three possibilities:
1. I have it in the wrong place.
2. I have the right place but am trying to mount it incorrectly.
3. The bracket is wrong.
Your thoughts? Anybody have an issue where they needed to do cutting and bending on the bracket? Whatever. I'm sure I can find something else to work on now. Thanks in advance!
