Results 1 to 11 of 11
Thread: Is there a template for hood/trunk/side badge positions
    How do you position them? Are there any set measurements to center them on?
    Member Kpt112's Avatar
    Bucks County PA
    It is funny you posted this because last night I drilled into the body and installed my side badges. I used blue painters tape over the vent opening. it is 1 inch so that is the hight I placed them over the vent opening. The vent opening is 7.5 inches wide to i split the measure measurement to so i got the center. I used some card stock to make a template so I know where to drill. I also used a 6-32 die to place threads on the post of the badge. That way I could take the badges off if i needed. I used some lock tight on the nuts so they would not back out.
    The badges are now centered over the vent 1 inch off the top.
    The whole process too me 1/2 hour. good luck. Did not do the hood or trunk.
    Cheers Kevin
    Santa Clarita, CA.
    Here is the best info. with measurements I was able to find.
    Keep in mind that these dimensions are bases on ERA Replicas.
    www.erareplicas.com/427man/body/emblems.htm
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    I got this from another thread on the other forum. These are for the hood and trunk badge.
    Front: 11.5" measured from the nose.
    rear : 18.5" measured from the rear edge of the trunk.
    Kyle
    Scott,
    TLAR ... that looks about right
    Woodstock ,Illinois
    Funny, I just stuck them where I liked them!
    O'Fallon, MO
    Quote Originally Posted by Garry Bopp View Post
    Scott,
    Quote Originally Posted by steno View Post
    Yep, put them where it makes you happy!
    Raleigh NC, OIB NC
    For the side 427 emblems I also used painters tape over the side grill to get a line, centered them over the grill. Trimmed & ground the backs flat & used silicone sealer to hold them on. Hood & trunk are "looks good to me" locations also siliconed on.
    Kevin
    MKIV #8234
    Mine are stuck to my toolbox. I didn't measure or use a template.
    Thanks everyone. Used the 1" blue tape on the sides and some measurements for the hood/trunk.
    Senior Member karlos's Avatar
    Littleton, CO
    Better pay attention, Jeff. More are headed your way soon. Expect to see them on the car and not your toolbox
