How do you position them? Are there any set measurements to center them on?
It is funny you posted this because last night I drilled into the body and installed my side badges. I used blue painters tape over the vent opening. it is 1 inch so that is the hight I placed them over the vent opening. The vent opening is 7.5 inches wide to i split the measure measurement to so i got the center. I used some card stock to make a template so I know where to drill. I also used a 6-32 die to place threads on the post of the badge. That way I could take the badges off if i needed. I used some lock tight on the nuts so they would not back out.
The badges are now centered over the vent 1 inch off the top.
The whole process too me 1/2 hour. good luck. Did not do the hood or trunk.
Cheers Kevin
Here is the best info. with measurements I was able to find.
Keep in mind that these dimensions are bases on ERA Replicas.
www.erareplicas.com/427man/body/emblems.htm
I got this from another thread on the other forum. These are for the hood and trunk badge.
Front: 11.5" measured from the nose.
rear : 18.5" measured from the rear edge of the trunk.
Kyle
Scott,
TLAR ... that looks about right
Funny, I just stuck them where I liked them!
For the side 427 emblems I also used painters tape over the side grill to get a line, centered them over the grill. Trimmed & ground the backs flat & used silicone sealer to hold them on. Hood & trunk are "looks good to me" locations also siliconed on.
Kevin
MKIV #8234
Mine are stuck to my toolbox. I didn't measure or use a template.
Thanks everyone. Used the 1" blue tape on the sides and some measurements for the hood/trunk.
