Results 1 to 5 of 5
Thread: Window Down Travel Stops....finally!
    http://vraptorspeedworks.com/window-down-travel-stops/
    I finally took the time to create some travels stops to limit the downward travel of the windows inside the doors. As most of you know, there is not enough room inside the doors for the windows to go all the way down into the doors without heavy modifications. Allowing the windows to go down farther than they should can (will) result in damage to the doors or windows. I have had 2 GTM's come into the shop where the window regulator actually separated the outer door skin from the door and we had to bond the door back together because the rear window clamp rubs against the outer door skin at the bottom of the window travel. On the driver's door, the bottom of the window itself usually ends up crashing right into the electrical connector on top of the window motor.
    These parts clamp onto the rear window regulator track to limit the downward travel of the window and can be placed anywhere on the track, making them fully adjustable to be placed exactly where they are needed to stop the window where the interference starts.
    Shane Vacek
    www.vraptorspeedworks.com
    LCD Gauges's Avatar
    Toronto, Ontario
    Very nice; I like the screw clamping design. You should sell these to FFR to package in their kit!
    wallace18's Avatar
    Trenton, Florida
    Great Idea! PM sent.
    Shane,
    Again great work another needed product from you. Something else that I will have to add to the build list requirements.
    Thanks guys! This is one of those things I should have come up with years ago. It's just one of those projects that I thought would be more complicated than it turned out to be and I have just felt too busy to deal with it. Even I was surprised at how well the very first prototype worked!
    Shane Vacek
