Results 1 to 10 of 10
Thread: Video shots -Wind Noise elimination
    mcwho's Avatar
    DeBary - Florida
    I have taken a few videos with my Canon Power Shot. It has hi res vid and stereo sound. Normally the video is good. I am trying to get a vid from inside the car, with the camera mounted in front of the passenger roll bar. I don't have the windshield installed as yet.
    It appears as the mike is on top of the camera body next to the on/off and function button. I have had no luck getting a good video AND good sound. My pipes are kinda quiet and would like to hear them, this last go I put a piece of tape over the mike.
    good video but no sound or only wind noise.
    Baghdad Bob
    Lost Wages, Nevada
    Try taping a small piece of open cell foam over the mic holes, that might let enough "pipe noise" in for your vid's.
    Doc
    Senior Member lahrs37's Avatar
    Jul 2014
    Philadelphia
    If you have a Mac computer you can record your audio on a separate device that is protected from the wind and sync it in the iMovie program.
    Here is the first tutorial I saw: https://www.youtube.com/watch?v=5aeuy6MrbHY
    I used this method on this video: https://youtu.be/nQDuYdjTCg8 and it looks pretty well synced.
    5.0 HO from a '93 Mustang, SVE heads, Trickflow stage 1 cam, Trickflow Street Burner intake manifold, T-5 w/mid shift, IRS
    Delivery 9-10-16, First Start 12-28-16, First Go-Kart 2-18-17
    Build thread: http://thefactoryfiveforum.com/showt...MK4-8951-Build
    mcwho's Avatar
    DeBary - Florida
    That's an interesting idea, I have looked at the microphone wind foam things and I DO have an Olympus stereo digital audio that I got for meetings. The audio is pretty good quality as well.
    I wonder if there is a tool for Windows 10 that I can use to merge. I'll check if that app "screenflow" is available for WIN 10.
    Baghdad Bob
    mcwho's Avatar
    DeBary - Florida
    I have a fairly new Windows 10 Machine that came with VIDEOPAD, I just tried it and I can edit video and audio from different sources as explained in Lahrs37 links above. This way I can get good sound and audio.
    Baghdad Bob
    Jul 2014
    Philadelphia
    Quote Originally Posted by mcwho View Post
    Glad I could be helpful. Hopefully you will share your video. You can never have/hear enough of a good thing!
    Sgt.Gator's Avatar
    Bend, Oregon
    I read where another racer had excellent results putting a RYCOTE Micro Windjammer filter on his video camera. I've ordered a pack of them on eBay, but it's taking a while because they are coming from the UK.
    Owner: Colonel Red Racing
    818R ICSCC SPM
    Cobrapreneur
    Cfehrenb's Avatar
    Jun 2017
    La Crosse, Wisconsin
    Baghdad Bob -- I'm late to this discussion, but thought I'd post if you still were searching for options. I've heard a similar complaint from FFRers who use GoPros. Several of this guys run an external mic from the GoPro down to the inside-driverside floor, right by the door. That area receives little wind noise. The mic picks up the pipes easily. Check your camera to see if an external mic can be plugged in. My Canon does.
    I agree with lahrs37 - hopefully you will share how it turns out.
    Craig F
    mcwho's Avatar
    DeBary - Florida
    Quote Originally Posted by Cfehrenb View Post
    Craig F
    I actually do have a Canon as well, and was considering a gopro, but haven't gotten one as yet. If I can use a remote mike with the canon, that may be a good solution. mine is a Power shot ELPH and has an AV out and an hdmi, don't see a mike input tho.
    Baghdad Bob
    Cobrapreneur
    Cfehrenb's Avatar
    Jun 2017
    Bob - would this work for you. It's something to consider.
    https://www.amazon.com/Sescom-DSLR-5.../dp/B008BMK3HE
    CraigF
