Results 1 to 15 of 15
Thread: Pre-1973 302 or 351 Windsor
    Senior Member jwebb's Avatar
    Longmeadow, MA
    Getting new MK IV kit delivered in June/July but struggling to locate a pre-1973 351 Windsor in New England either built or ready to build. Need pre-1973 block/motor to avoid Massachusetts emission requirements!
    Milton,DE
    Check with Mike Forte.
    http://www.fortesparts.com/
    Olli
    Sep 2015
    Beachside
    As Ollie said, check with Mike. He built my 289 motor off a 1965 block. We just did the first start on Saturday. Runs great.
    Mark from Breeze also has a 289 motor ready to be rebuilt on his website.
    Clean blocks seem to be getting harder and harder to find....
    FFR #8833 289 FIA 3-link
    Colorado Springs
    Consider searching craigs list for an old car or truck with the right engine. Then you'll have a clean title and bill of sale. And you'll have all the nuts, bolts, and brackets you might need.
    Remember that Ford is not like Chevy. There is no such thing as a numbers matching Ford.
    .boB "Iron Man"
    www.RacingTheExocet.com
    Longmeadow, MA
    Pre 1973 Motor
    Quote Originally Posted by cnutting View Post
    Did you do a turn-key Engine/Clutch/tranny through him? Curious of your cost & what did you end up with from a HP perspective?
    Sep 2015
    Beachside
    Yes, I did the turnkey option with the TKO-600. Cost me a little bit more going with the vintage block since there was a bit more machining, but it was worth it. Engine makes just over 340 hp.
    https://youtu.be/9QYdSMusvP4
    Where in Mass are you located?
    Longmeadow, MA
    Located in Longmeadow, outside of Springfield! Have you run the State Police inspection? With the old 289 you are able to avoid emissions testing!
    Longmeadow, MA
    Sounds fantastic!!
    Sep 2015
    Beachside
    Haven't been through that yet, but the folks at DEP verified my block casting number meets the requirements, so hopefully that goes smoothly.
    Give Mike a call, see what he says. He's been a huge help, that's him in the video tuning the engine.
    Jwebb,
    You may also want to look on Ebay, Craig's List, local news paper or local wrecking yards for a complete running old car because a friend of mine just bought an FE-390 Powered 1960's T-Bird just to get the motor for his next build. I think he paid between $3,500-$4,500 for it and drove it home to boot. In addition, please know that I am not saying to look for an FE-Motor or 385 series engine, but finding a power plant from the desired era.
    Examples:
    http://www.ebay.com/itm/1963-Mercury...pYo9bC&vxp=mtr
    http://www.ebay.com/itm/1966-Mercury...VYrGav&vxp=mtr
    http://www.ebay.com/itm/1972-Mercury...ZYgBrL&vxp=mtr
    Also, if you see something within 30-45 miles of N.O.L.A. then let me know because I don't mind making a milk run for you because that is what we do on this forum.
    Note:
    That friend is Hottrodder427 on this forum.
    Good Luck!
    Senior Member brewha's Avatar
    Somers, Ct
    Hi Jwebb. I'm just south of you in Somers. I got my kit in March. You should stop by so we can talk about the great local support I've found just in our area. I got a 1969 block being stroked to 331 which should be finished soon. Welcome to the craziness.
    Longmeadow, MA
    Pre 73 Engine
    Quote Originally Posted by jwebb View Post
    Found one, a 69 302. thanks to all for the suggestions! Jwebb
    Longmeadow, MA
    Quote Originally Posted by brewha View Post
    Brewha, Sounds good! How far along are you? Who's doing the motor? Any connections for a 8.8 rear housing?
    Somers, Ct
    Mine is a roller. It's nice to be able to roll it in and out of the garage when the suns out. I'm running the fuel lines now.
    I got my Moser rearend from Fortes. I saved some cash on shipping by picking it. The banana bracket took some work fitting it and then I had it welded by Reliable Welding for $70. F5 has a Moser with bracket already mounted. My motor is at a local builder (Eastwoods) waiting in line for assembly. I'll send you a PM with my phone number if you ever want to stop by. I'd show you the cost of things that I purchased. I work on it daily since I' m retired.
    Longmeadow, MA
    First 302 ended up being 30 over already, but found another in Portland Ct that's std bore. Also picked up a rebuilt 8.8 @ Forte's yesterday. Things are coming together slowly
