Results 1 to 3 of 3
Thread: Seat Belt Question
    Mar 2017
    Seat Belt Question
    When using the stock WRX wagon seat belts, where do you mount the lower bolt?
    Senior Member fastzrex's Avatar
    Oklahoma City
    One of the great unanswered questions in the assembly manual. In essence, as far as I can tell, you are on your own to engineer the solution. I am working through this problem now. But I believe the build section and this area will provide some ways on attaching that end of the seat belt.
    ~ Mark
    818C S/N 429ES: Start Date 1 September 2016
    2001 NB Miata LS3 V8 440 rwhp
    2004 Miata MazdaSpeed Factory Turbo
    Banned
    There are a few threads on the subject if you search.
    Most drill and bolt through the outer bottom square tube. You will have to find a longer, high quality bolt and some thick fender washers to prevent crushing the tube or pull through.
    The seatbelt locations are not covered in the manual because what works for one driver/seat combination could be fatal for another. This is one of those things that requires a bit of common sense and enough modesty to raise the white flag and call for help if you aren't sure of yourself.
