Results 1 to 2 of 2
Thread: Heim Joint Lubrication
    I was trolling the HAMB (Jalopy Journal) forum today, and came across this interesting thread about heim joint lubrication.
    https://www.jalopyjournal.com/forum/...cation.559699/
    Now I am pretty sure the heim's we get from FFR, for the 3 link suspension, etc., are not Teflon lined ones. I'm not sure about the factory ones on the Koni coil-over shocks though? I see the optional seals available for heim joints is mentioned, as a good idea, but then that is countered by another, who claims that the seals can also trap moisture in the joint.
    I don't know if there is a 100% right way or a wrong product, but the people posting sure appear to use a wide spectrum of lubricant's, from dry graphite, Never-Seize to simple WD-40..
    So what product and method do you use?
    Heart of Dixie, Alabama
    I would suggest something that dries after application. Oily will hold grit. Check on some bicycle chain lube. It has a liquid carrier that dries after the teflon particles migrate between the mating surfaces.
