Getting ready to install the factory carpet over the sound/heat insulation. Has anyone out there done this installation and could share a few tips? The book says to start at the front of the tunnel and glue it as you go. I've tried trial fitting to no avail so I guess I will have towing it unless someone can offer guidance. Once this stuff is glued down, it will destroy to foam if I have to move it.
