Removable Passenger Rollbar
Hi Guys,
I found out my local track requires a passenger roll bar, if I want to take a passenger for a spin around the track. I assume most tracks are this way. I'm not real crazy about having two roll bars in the car all the time, so I was thinking of making the passenger side removable. I'm pretty sure this has been done before. I searched the forum, but I'm not finding anything. Can someone point me in the right direction? I am curious as to how difficult it is to install and remove the roll bar and how the builder did the plugs to fill in the holes.
Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018, Engine Dyno'ed 3/4/2022, Engine installed 8/27/2022
Serial #9158
Someone on the other forum made trim rings that had a spring loaded center just for this purpose.
I certainly wouldn't ride on the track without a roll bar. You should also be wearing arm restraints. I know a guy that rolled his EM Cobra on the track. Three years of therapy because he didn't know about them.
Frank-
I believe that Greg did this mod, and details it pretty well on the other forum. Do a search under Greg_M, and I think you will find what you are looking for. pcww also mentions thinking about doing it, but I am fairly sure that Greg is the only one to have actually done it.
Good luck!
Thanks WIS89. I know I've seen something about it somewhere. I haven't looked a the other forum for a long time. That's probably why I couldn't find it. Thanks!
Serial #9158
