Page 2 of 2 FirstFirst 12
Results 41 to 49 of 49
Thread: Can't Shake a Lean Condition - HELP
    Des Moines, IA
    MAF looks good. Voltage and wiring looks correct as well.
    Wondering if I have a fuel pressure issue. . I turn the key on. It primes to ~40 psi, and then the pump turns off. Within 1-2 seconds, the fuel level goes to ~20 psi, and to zero within 7-8 seconds. Assuming this isn’t normal from other post I have read on NASOIC. I had in my head there was an drain back valve. If yes, is this s on the pump stock in the tank?
    maine
    If you have to open the throttle to start, sounds like it's too rich. Can you adjust cranking pulse widths?
    Quote Originally Posted by mrbiglar View Post
    There are 3 condition that the full pump should be running.
    1. for a few second after ignition is turned on.
    2. while cranking the starter.
    3. while engine is running.
    The fuel pressure dropping to zero in 7-8 seconds indicates to me a problem in the fuel system.
    I would expect it to hold pressure for minutes or even hours.
    1. bad check valve in the fuel pump (in tank).
    2. bad valve in the fuel pressure regulator (normally under intake manifold).
    3. leaking fuel injector.
    4. leak somewhere between pump and FPR.
    EDIT: your Perrin aftermarket FPR is bolted on top the intake.
    San Diego Ca 92106
    Just to add to what Bob said, a leaking fuel injector could lead to fuel in the oil, very bad. But a leaking injector should make starting warm a little more difficult right? Behaving like a flooded condition?
    Des Moines, IA
    Pretty sure I have a bad check valve on the fuel pump. Put Subaru OEM FPR on and it still wouldn't hold. New pump on the way...
    Thanks for insight. Will let you know how it turns out.
    Des Moines, IA
    Bad Check Valve on the pump. Swapped for a DW300 (much quieter than the Wahlbro). Started right up. Thanks all for the help!
    maine
    Yes they are, Glade your up and running!
    Senior Member AZPete's Avatar
    Whew, finally after 5 months! I've been following this all along not because I could help, but to learn what could cause the lean condition. Congrats, Mrbiglar, and thanks for the lessons.
    Senior Member fletch's Avatar
    Dec 2018
    Just outside ABQ, NM
    Mrbiglar,
    Per the schematic below your pin 3 & 4 are backwards. Black wire should be on pin 3 and white wire should be on pin 4 of the sensor.
    I had the same issue as the OP -persistent too lean, AFR & AF Correction pegged at max values. Double checked everything, swapped O2 sensors, etc. After reading this post I decided it was worth a try swapping sensor + and - to see if the condition would reverse. In fact, the pin swap fixed the problem. Turns out the 2006 FSM has sensor + and - swapped.
