0
0
Control arm hardware
I'm using donor control arms on my Mk4 base kit. I was assuming I need to supply the attaching bolts, but I noticed the build manual says "87-93 - Mount the lower control arms using the outer set of holes on the chassis using the supplied hardware" I can't find any bolts in the front suspension box, so I think it is a misprint in the manual. Just figured I would ask if I am missing something. It would be nice if they came with the kit as I don't have them. Thanks.
