Thread: Undercoating, Fire wall, Heat & Sound deadening options
    Question Undercoating, Fire wall, Heat & Sound deadening options
    What are some of the options everyone has used for their firewall, undercoating, heat & sound deadening materials (mats, spray,s, etc...)? 818C ~ would like to cut down on road noise.
    I have seen a lot on the build threads, from truck bed lining, adhesives, fat mat to HVAC liners! Any recommendations for each application? I am not too concerned about adding additional weight, just want to know the best options out there.
    Des Moines, IA
    Used Lizard Skin on the interior for sound and heat protection. Great Product...very impressed.
    A local manufacture sent me experimental heat insulation. It is adhesive backed, 3/8" thick, thick embossed foil on heat side with fiberglass wool inner layer. I'm guessing 3 to 5 lbs for rear firewall.This is what it looks like after 2 years 3000 miles. I am very happy with it.
    Senior Member Blwalker105's Avatar
    This is an excellent, lightweight product. One of the many places I used it was on my plane's lower engine cowling which came within 3/4" of the exhaust headers. Never saw any issues with the fiberglass or the exterior paint.
    http://www.thermotec.com/products/ad...t-barrier.html
    Sep 2015
    Hamersville, Ohio
    I added an extra outer layer of aluminum skin to my framework around passenger compartment which I plan to coat with the lizardskin product. I'm only coating the side that contacts the framework. Hopefully this will quiet the interior a bit. Might prevent rattles too.
