Results 1 to 5 of 5
Thread: Digital Guard Dawg Troubleshooting help?
    Oct 2014
    Redondo Beach, CA
    I am using the Digital Guard Dawg as my ignition source for my electric 818. I'm having some odd behavior. I was in contact with EJ @ digitalguarddawg, but he seems to think the unit is broken and now won't respond. I saw a few posts with people using this on their builds and thought maybe someone might have some insight. It seems the modules (PKE and PBS) are working, however I have to ground the "Ground When Disarm" output. If I don't, the units do not come alive. This is strange behavior seeing as this should be an output.
    Quote Originally Posted by ninjanick View Post
    Nick
    Sounds like you don't have a good ground on black wire of 8 pin connector.
    Oct 2014
    Redondo Beach, CA
    That was one of the first things they recommended so I tied the ground directly to the battery. Still same behavior. Could it be length of wire? Ground to frame is about 6". I'm getting less than 0.2ohms from the ground point to the battery negative terminal. My DMM isn't the most accurate especially at that low reading.
    Length shouldn't mater.
    When you take the "ground to disarm" wire to ground and it turns on the unit. It is saying to me that the normal ground is not there. I would check the crimps inside the connectors. If they are good. Problem is probably inside box.
    Oct 2014
    Redondo Beach, CA
    Bob,
    You were right ... so I went through the ground path and re-checked everything. The supplied harness double crimps both module grounds into a single contact. It held together ok, but it had a lot of gap to insulation on one of the conductors. So I added a little bit of solder and shrink tubing. Seems to work fine now without having to "ground" the output signal. Thanks for the tip!
