Thread: Wiper Motor Wiring ?
    Jacob's Avatar
    Rogers, AR
    Does anyone sell a male plug-in that will match up to the female plug-in on the wiper motor? Seems like it would make a neater more fail safe way of making connections...thanks!
    MK IV complete Kit - 1st time builder started Sept 2016
    Levy 306
    T5
    2015 Mustang IRS
    Power steering - Levy setup, Breeze roll bars, Thompson trunk box
    fuel injection, powder coating, sway bars, heater, wipers, 17 in wheels
    Norton, MA USA earth
    Senior Member Misterfubar's Avatar
    Olathe, KS
    Here is a cheaper option. Shipping is $7.50, but still saves a few bucks.
    http://www.britishwiring.com/Wiper-M...5.htm?CartID=1
    Ohio
    I have the plug from ********** on my Mk4. It comes with no way to lock onto the wiper motor. Had to put a tie wrap around it and the motor. If I had to do it over again I would just plug the wires onto the spade terminals in the motor housing and seal it with silicone. Easier and saves some money. If the plug came with a lock on it like all other automotive plugs have it would be worth it
    JRL16
    Mar 2017
    I did that with mine using the insulated spade connectors and potted it with silicone. Then put a connector on the end of the short harness.
    I do the same as Conger
    Fairfax Station VA
    Quote Originally Posted by conger View Post
    Do you happen to have a picture handy?
    MK IV Roadster #8631
