Thread: Any ideas on how to reduce the engine heat coming into the cabin, past the dash?
    Discovery Bay CA, and the car is in the hangar in Stockton CA
    Question Any ideas on how to reduce the engine heat coming into the cabin, past the dash?
    Have a MK IV I completed in 2014. Great car, lots of fun, but when the outside temp is over 90 deg, the hot air passing by the manifolds enter the cabin by the front of each door. If I could block that hot air, the car would be much more comfortable to drive. Any ideas?
    Nov 2016
    "The i.e." SoCal
    Two words; Pool Noodle.
    The kit includes expanding foam and the instruction manual shows installing right before the body is installed for the last time. But common that the step is missed or another method is used instead. Some options in this thread: http://www.ffcars.com/forums/17-fact...-firewall.html
    Two more words; air conditioner foam---
    OK, I guess that was 3 words
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    Go with this option, it so works.
    Kyle
    Ohio
    I used the insulation Jeff recommends. It works very well with just a little shaving. Seals completely
    JRL16
    #9160 BB767's Avatar
    Chehalis, WA
    Hi Bomber,
    I am looking into building a roadster next year, seeking input and information on the cars. Would like to meet you and your car sometime. I am up in Somerset, a great afternoon drive from Stockton, if you need a reason for a drive! Otherwise, let me know if we can meet up sometime when you have the car out.
    Thanks, Brien (BB767)
