Results 1 to 2 of 2
Thread: Heater Bypass Valve Location
    First post! I have been reading and searching a lot and have had enough of seeing people say check my build site but I don't have enough posts to view links in signatures.
    Where are the common locations for mounting the heater bypass valve?
    I am leaning towards the front of the car (to reduce the # of wires through the tunnel) but I have seen a few builds with it either in the tunnel or behind the engine cover.
    Clarksville, MD
    First, welcome to the GTM forum! Glad you've taken the step to join and post.
    I put mine down low below the waterfall cover. I can get to it from the access panel under the car or by removing the waterfall cover. Also keeps some of the tubing short and out of the tunnel. And a short run for the vacuum line that actuates it. Just my $0.02.
    Good luck with the build!
    -Michael
    GTM #327, LS3, G50/20, Kooks, AC, Ron's Tanks, Crash's 4-port HCV, Shane's Bolts & Plenum & etc., plus a lot of other stuff. Finished November 2013.
    Not-up-to-date Build Site: http://rumrunnergtm.weebly.com
