Hello All.
My soon to be 17 year old MK1 is sagging in the back where the rear tires are about even with the fender lip. I'd like to boost it up to an inch or so. Last year I removed the wheels and loosened the suspension enough that I could rotate the coil springs to raise the rear. It looked good for awhile but eventually the coils went back to their droopy spot due to rough roads.
Is there a way to turn the springs to lift the rear then put some type of bracket to hold it. Is there such a thing?
How would you guys approach this problem?
Thanks.
