Results 1 to 2 of 2
Thread: Seat belts?
    Nov 2015
    Elverta, CA
    Seat belts?
    I am not going to use the Simpson racing harnesses for this car. I would like a simple retracting lap belt with a oem type inboard rigid arm. Something simple but effective. The issue is if the retracting housing will fit in the area beside the rear outboard seat corner. Has anyone used this solution and did it work for you? If you were able to fit something similar with a shoulder harness please reply as well. Thanks..
    Oct 2014
    Vermilion, OH
    Look at Eric 33's build page, he used a 3 point seat belt that looks good. I'm probably going to do something very similar.
    CVOBill
