Results 1 to 8 of 8
Thread: Gas Shocks for Hood Alignment?
    Senior Member metros's Avatar
    NoVA
    I'm using the ZDB Motorsports hood hinges with the updated front end. I'm finding that there is so much flex in the hood that when I lower the hood it doesn't always go straight to where it fits in perfectly. This is after I have already bonded 4 strips of aluminum to the hood to stiffen it up, which did help some.
    My thought is to use gas hinges (1 driver side and 1 passenger side) in order to compensate. This would come with the added bonus of propping the hood in a stable manner when it's opened. Then when closing it would be guided by the gas shocks. Has anyone else done this? Any ideas or thoughts?
    Jan 2012
    I know Craig had some design to add the gas struts but the cost was too high i believe. I was thinking of doing something similar but haven't found anything that I liked yet. I'm very interested as I'm having the same problem.
    Freeport, ME
    gas hinges are not needed as it's so light and flimsy. The solution is to have a hood with a liner that has 3D features so it doesn't flex so much
    Banned
    You would need to significantly reinforce and stiffen the hood where you attach the springs or it'll just flex anyway and still not line up.
    And I would seriously doubt that an air spring would have the ability to locate something as tightly as it sounds like you want.
    Mechie3's Avatar
    If you look at the hood hinges, most of them have an extra hole near the 1/2" shoulder bolt. The latest versions don't have the hole but still have a bump out where the hole can be added(taking out the hole saved $5/part since it had to be drilled and not laser cut). The original idea was to use a gas strut to hold it open and, when closed, it passes the toggle point and pulls it down a little bit. I couldn't find miniature shocks for less than $50 ea.
    Jan 2012
    What size where the miniature shocks that you were looking for?
    NoVA
    Any more details that you can provide would be great!
    Mechie3's Avatar
    http://www.indgassprings.com/micro-g...choose-fitting
    Part number is 4-1.5-5.11
    I chose those because I have a bag of 6 of them I salvaged from the trash.
