Results 1 to 5 of 5
Thread: Dead Pedal Aluminum Panel
    Senior Member fastzrex's Avatar
    Oklahoma City
    I am back working panels as I wait on other parts. This morning, I was fitting the 'Dead Pedal' panel with the panel immediately outboard. On pages 168-169 in the manual, there is not any opening at floor level where these panels meet. As you see in the attachment, there is a large gap that will allow the front area forward of the firewall to have direct flow of air into the cockpit. Maybe I am missing a step later in the build which now 'plus' this hole? Or are the panels (they do not have part numbers on them) mismade or for a different model?
    ~ Mark
    818C S/N 429ES: Start Date 1 September 2016
    2001 NB Miata LS3 V8 440 rwhp
    2004 Miata MazdaSpeed Factory Turbo
    Senior Member AZPete's Avatar
    You have the correct pieces. After you run the coolant lines, and other lines, through the dead pedal, you'll cover that opening with this piece. It looks like the number is 80604 in this photo and you'll want to tuck in the ends before riveting, of course.
    Oklahoma City
    Quote Originally Posted by AZPete View Post
    Thanks! I will look for that piece. I just missed it evidently.
    Later:
    Found those two panels as you predicted. I guess the car was updated and the manual was not in some places.
    ~ Mark
    Senior Member mistasherm's Avatar
    East Central PA
    Boy I'm glad I wasn't the only one that got stumped on this one...hopefully you didn't spend too much brain power trying to unravel the mystery like I did. I must have spent have a day and two calls to FFR trying to figure it out. The pic AZPete sent is correct; although you may have to do some small cutting and "coaxing" to get them all to line up...
    Oklahoma City
    Thanks for your reply. I did spend about three hours researching and waiting on FFR to respond before posting. I was thinking about fabricating closeouts (trying to prepare panels for paint in preparation of install when 'help' arrives) when I checked the forum and again AZPete helps out. After reading a little more I see that the radiator tubes are '2nd gen' and are bent instead of straight as in the first rendition. The manual just has not caught up yet! I have one fitted and drilled after a little 'coaxing'; starting work on the other side.
    ~ Mark
