Results 1 to 11 of 11
Thread: How Far can I go with my build without an engine?
    Apr 2014
    Memphis, TN
    I am going to be starting my build in the next few weeks but I don't have an engine/transmission picked out yet. How far can I go in the build before I need the engine/transmission? Looking through the manual I am thinking I can go through the chassis build up: front and rear suspension, Pedal box, aluminum panels, steering column and rack, and brake lines. How much farther can I go? Main reason for waiting on the engine is: 1. room in my garage (I would like to make some progress on clearing out boxes before taking on the engine) 2. Money (wife didn't complain when I bought the kit, I don't want to push my luck for a while)
    Thanks.
    May 2016
    North of sacramento Ca.
    As long as you stay with a standard engine trans setup probably not a problem.
    Agree with 1932, as long as you're going with an engine & trans supported by FFR you should be able to get a lot done before needing the engine. However, since you haven't decided on a power train yet you should not purchase a driveshaft with your kit. You will need to decide on a rear end type before ordering and if going with a solid axle, you'll also need to choose between three-link and four-link.
    Apr 2014
    Memphis, TN
    Thanks. I am buying a used kit that is already coming with the rear end. It will most likely be a SBC build so pretty standard there. Just trying to figure out how far I will be able to go before I have to have the engine.
    SBC is a great choice and easily fits.
    Prairieville, Louisiana
    I'm glad you asked this. I was curious also. I'll be using a coyote and 6r80. The coyote is supported but that auto isn't. I intend to get all the chassis and body work done but I won't install floors yet till I make sure I don't need to mod the frame. I figure I can out the body on, get all my canes done, get everything fitting and working right, get it primed and wet sanded and then take it off once I get the motor (hopefully next summer ish). Maybe even get the chassis wired and even interior wired, top fit, doors and windows wired and working, inside ac stuff plumbed and working.
    Spending on how involved your build is, there is tons you can do before you need the drivetrain.
    '33 Hot Rod
    MK4 Roadster
    Ol Skool
    upstate NY
    I am a proponent of waiting as long as possible in the build before putting the engine in. I don't like fresh engines sitting around collecting dust, literally, fiberglass everywhere, no coolant protecting the block and keeping the pump seal lubricated, etc. That said, its very difficult to get driveline centerline, exhaust, and clutch setup without the engine and tranny. For the exhaust and tunnel you kind of need them unless your building a very standard SBC/SBF and clutch cable T5 set up. I don't think PAYR has made a mock Coyote long block yet. I like to have a spare block and heads for mock up. This is easy with a 302 ford and inexpensive. If your doing a build in 3 months it doesn't matter, but, if you know it will take a year its probably best to hold off on the engine. It will give you time to find a good deal on one also.
    Apr 2014
    Memphis, TN
    Thanks that is my thought on the engine as well, I don't want a perfectly good engine just sitting around for a year or more. As much as I would love a 3 month build my guess is at least 2 years. I have 3 kids under 6, and I work a lot of hours. This things will be put together after 9pm, and before 6 am. I think based on what you are saying, I am just going to plan to keep working on things until I get to a point where it looks like I am running out of things to do without engine. That may take 6 months or a year. Plus my father in law found me an engine within 30 minutes of telling him about the project, so I may come up with an engine by accident which is kind of how I found the kit.
    Member Frank Messina's Avatar
    Yorba Linda, CA
    I'm not proposing you do this but companies like Superformance, Backdraft and even ERA completely finish the car MINUS engine and transmission. The difference is they've done hundreds and know where everything is supposed to go. Point is, you can get pretty deep into a build before actually needing the engine and transmission. In many cases builders start looking to install the engine when they hit an ugly part they'd rather put off until way later. Like the wiring for instance.
    If the engineering on the 33 Hot Rod is anything near what it is on the MK-4 and you don't go off of the reservation by installing an unsupported engine and transmission combination, then I think you are safe to complete the entire chassis prior to installing your drive-train.
    That's what we did at Camp Go-Dad-Go.
    https://youtu.be/3f1Q4aS5SG4
    Plan Your Build & Build Your Plan!
    However, since you haven't decided on a power train yet you should not purchase a driveshaft with your kit. .
    I knew that my Hemi 47RH combo would need a custom length shaft so I ordered the kit with the longest shaft FF had then I had it cut to length
    locally once all the variables were locked in. That worked out well for me.
    Dale
