Results 1 to 10 of 10
Thread: Brake Line T fitting
    Senior Member jlfernan's Avatar
    Port Orange, Fl
    I seem to have misplaced one of the brake line t fittings. Anyone know where to get a replacement or the specs for the ones included with the kit?
    Check Napa auto stores
    Albuquerque, NM
    Quote Originally Posted by jlfernan View Post
    As mentioned, any auto parts of hardware store should have it. It's meant for 3/16" brake hard line which uses 3/8"-24 inverted flare fittings.
    -TJ
    O, Reilly's even sells the rhinohide brake line provided in my (33) kit
    Port Orange, Fl
    Same thing as in our kits? Visually it's a little different. Description sounds right.
    https://www.summitracing.com/parts/k...2355/overview/
    Senior Member karlos's Avatar
    Littleton, CO
    Pretty sure I have one I'd be happy to donate to you. I installed a line lock in the front brake system and the solenoid takes the place of the tee, so I'm reasonably sure I have an extra. If you're still looking for one I can dig through my spare parts and let you know.
    -Karl
    Port Orange, Fl
    Quote Originally Posted by karlos View Post
    -Karl
    If you could send it to me I would appreciate it. O'Reilly's has one identical but the male portion Is metric thread. I'll PM you my address.
    Littleton, CO
    Is this it?
    Port Orange, Fl
    That's it!
    Littleton, CO
    On its way...
