Results 1 to 18 of 18
Thread: Advice on MKII Power Steering Conversion
    mburger's Avatar
    Punta Gorda FL
    Hello.
    So I'm looking to convert my MKII to PS. I received a quote from Breeze for everything I need to convert. Mark at Breeze has his remote reservoir mounted up on the passenger F panel but I don't have the room there. At least I don't think I do. Mark's design for the MKII mounts the pump on the lower passenger side so I don't want to mount the reservoir on the drivers side. I didn't want to have the hoses run across the engine bay. Breeze's design would move my alternator to the upper drivers side and I'd get rid of the stock belt tensioner. I guess I'm looking for thoughts on reservoir placement. Or any other comments.
    Breeze also has a driver side PS pump mount.
    http://www.breezeautomotive.com/deta...=668&cat_id=12
    Looks to me like your have room on the driver side for the reservoir. And the ports on the rack are driver side so that seems to be the standard-all on driver side.
    Senior Member MPTech's Avatar
    St. Louis, MO
    Stock Mustang PS Pump & rack work very well. I'd also suggest adding a Hiedts valve for adjustment.
    mburger's Avatar
    Punta Gorda FL
    Hi Craig,
    Looking at the area, I thought I had plenty of room on the driver's side, but Mark at Breeze who has an MKII said, "Our pump bracket is a low mount and will not clear the remote oil hoses or the steering shaft, so we put the alternator there and the pump on the passenger side." I know the MK3 and 4 steering shaft do not get in the way.
    Ideally, I'd like the pump there and reservoir on the drivers side as you suggested. I'd hate to order everything from Breeze only to find out, oops, Mark was right!
    Mark
    mburger's Avatar
    Punta Gorda FL
    Hi MPTech,
    I thought of using the Ford "AC Eliminator" bracket and putting a Ford reman pump right where my existing pulley is and be done with it. I guess I was thinking of cleaning up the front of the engine while getting this conversion done. I've searched the forums and created a parts list from all the other helpful builds/conversion posts. While the Breeze solution wasn't the cheapest, it offers the convenience of one stop shopping. One order and I get everything I need, but there's no benefit if it doesn't fit. I'm also going with a 3 turn LTL rack and the Hiedts valve is probably a good idea. I know some folks cut the spring, but your suggestion gives easier adjustments.
    I tend to over think things if you haven't noticed.
    Heart of Dixie, Alabama
    Is electric steering an option you would consider?
    Member Frank Messina's Avatar
    Yorba Linda, CA
    MPTech gave the answer. Mustang PS pump and rack with Heidt's valve for adjustment. Everything fits and works perfectly.
    mburger's Avatar
    Punta Gorda FL
    I hadn't considered it seriously because I know so little about it.
    mburger's Avatar
    Punta Gorda FL
    Quote Originally Posted by Frank Messina View Post
    I'm leaning this way and because Mark at Breeze has been so helpful, I'll still get most of what I need from him.
    Not trying to argue w/ Mark for sure but...if you can figure a way to put the PS pump on the driver side no need to move the alt and you could still use your tensioner. My MkII has the Breeze driver side mount but a 99 Explorer pump which looks a lot like the Breeze Jones Racing pump. It is no where near the steering column but might be a problem for the oil hoses as Mark says. I see in his pic of of the driver bracket and a pump installed on a car, it is the style w/ the built-on tank which is super wide. Maybe the remote reservoir version would work. See how small a bare pump is.
    http://www.breezeautomotive.com/deta...=667&cat_id=12
    Also, you could perhaps re-drill the holes for the pump to move it up higher on the bracket-looks to me like the pump could be raised at least 1.5 inches. Just throwing out thoughts to try to maker this as easy as possible.
    Member Jim Doak's Avatar
    Midway, Utah
    Have you considered a KRC power steering pump? That's what I used when I converted my Mark 1 to power steering in 2005/2006. The pump mounts on the driver's side. The only issue I had was finding a location to mount the P.S. reservoir; however, I believe that KRC currently makes pumps with integral reservoirs.
    Here's an old picture from 2005 during the conversion process.
    As you can see, I'm running a V-belt setup. You could check with KRC and see if they have serpentine power steering pump setups.
    Fairfax Station VA
    Have you considered a Fast Freddie's kit ( http://www.fastfreddiesfabrications....p?id_product=4 )? It's designed to fit right where your remote oil cooler is now, but it's not hard to modify the pump mount to put it wherever is convenient (say, to one side of the forward X). You'll probably have to modify your oil filter lines, or live with the aesthetics of various fluid lines criss-crossing your engine compartment.
    MK IV Roadster #8631
    mburger's Avatar
    Punta Gorda FL
    Thanks everyone for all the suggestions! I looked at KRC and Fast Freddie's as well as a couple other options, and they look like good options, however I decided to go with the Ford Motorsport raman pump along with the Heidts valve and Ford Racing AC Eliminator bracket. Mark at Breeze whipped up a new BOM for everything else I need. I think this is the simplest option for me and keeps everything on the drivers side. No need to change the water pump for a CCW etc. I'll just need a new serpentine belt.
    I will post pics when complete along with a parts list of everything needed for the conversion to help someone else wanting to go this route.
    Mark
    The KRC bracket looks to mount the pump higher than the Breeze unit
    http://www.krcpower.com/ecommerce/pu...racket-kit.asp
    Also it looks like it has a long slot to allow the pump to move to adjust belt tension.
    Ottawa Ontario
    I have a MKII and used the CFR front dress with a stock Ford pump. Everything clears and works fine. They also usually have a 30% off sale on July 4. Scott
    Quote Originally Posted by mburger View Post
    There is an article on the other forum or you can search YouTube for a video. You can add adjustable p/s to your car for about $150 using your current rack and steering column. You can turn up the boost for around town driving so it is really easy to steer, then drop it down for highway.
    https://www.youtube.com/watch?v=uKzCaEjvJeM
    O'Fallon, MO
    Mark
    Just so you know, you already have CCW water pump, maybe you meant to type CW?
    mburger's Avatar
    Punta Gorda FL
    CraigS - thanks for the link.
    Johnnybgoode - Nice looking engine. I'm checking out CFR Performance.
    joyridin - That is pretty cool. Never heard of that before.
    rich grsc - oops. Thanks for correcting that. Indeed it does turn CCW.
