Results 1 to 11 of 11
Thread: Transmission A-frame Mount Bracket
    Senior Member jwebb's Avatar
    Longmeadow, MA
    Another frame question, just got my frame back Friday night and kicked off the build again. Completed the front end and moved on to the rear and noticed the mount bracket wasn't centered in between the frame rails. Please tell me this is correct?IMG_0707.JPG
    Fairfax Station VA
    It's correct. The driveline is offset towards the right side of the car. When you unpack the transmission support, you'll see it's offset as well.
    Speaking of which, test fit the transmission support BEFORE installing the engine-transmission assembly. On my car, the forward tabs of the support had to be ground down a fair amount before it would fit into place; the tabs interfered with the 4" tubes such that the mounting bolts wouldn't go through. After I got the support installed, I left it in place when installing the engine. This is backwards from what the manual says to do, but it worked out just fine. You'll appreciate a helper who can lift the tail of the transmission into place.
    MK IV Roadster #8631
    O'Fallon, MO
    John beat me to it.
    Longmeadow, MA
    Thanks again, my bracket is on backorder so i couldn't do a fit check to verify the mounting but I certainly will !!
    slpro1207's Avatar
    Moorpark, CA
    This is a example of why this forum is so great. I never thought to test fit the support bracket before installing the trans. But I will today. Thanks guys.
    MK4 delivered 2/24/2017. Complete kit #9023,IRS, Power Steering, Leather, heater, 17" wheels, sway bar ft & rr, tremec 600 and Gordon Levy Racing SBF 427. First start and go kart 8/19/2017. Graduated 1/15/2018
    MK4 #9230 complete kit delivered 1/27/2018. IRS, PS, leather, Tremic 600, SBF 427. Graduation 10/15/2018
    MK3 #5253 donor bought unfinished. SBF 331, T5 Trans.
    Ohio
    One thing you should check is your e-brake cable bracket. Mine interfered with my driveshaft u-joints so I had to grind the corner off the bracket.
    JRL16
    Fairfax Station VA
    Quote Originally Posted by JRL16 View Post
    Likewise if you install a drive shaft loop. I moved my e-brake cable bracket so the cables would clear the loop, and then moved it a second time so the cables would clear the floor pan. Poor planning on my part led to re-work.
    Longmeadow, MA
    Thanks for the heads up!
    Are they still having that issue? That was a problem builders discovered back 10 years ago or more. You think FFR might re-think that bracket by now?
    Maybe the guy that welded the LCA tab on backwards also makes the trans brackets?
    1. E-brake bracket. The rear one. Not the trans bracket.
    2. This problem was reported by 2015 IRS builders. FF confirmed the part is hand placed so there is obviously some variation. Mine cleared but I did trim is slightly to give additional clearance. Others reported no clearance without some trimming. Not a big deal IMO, but agree less variation would be good.
