Results 1 to 6 of 6
Thread: Rear IRS brake rotor play
    slpro1207's Avatar
    Moorpark, CA
    When I was mounting my rear wheels today I noticed I had a lot of play in on to rotors. Is this normal?IMG_0249.JPGIMG_0250.JPG
    MK4 delivered 2/24/2017. Complete kit #9023,IRS, Power Steering, Leather, heater, 17" wheels, sway bar ft & rr, tremec 600 and Gordon Levy Racing SBF 427. First start and go kart 8/19/2017. Graduated 1/15/2018
    MK4 #9230 complete kit delivered 1/27/2018. IRS, PS, leather, Tremic 600, SBF 427. Graduation 10/15/2018
    MK3 #5253 donor bought unfinished. SBF 331, T5 Trans.
    Melbourne, Florida
    Sure looks odd. However, once the wheels are tightened down, play around the wheel studs doesn't matter. I'm assuming these are the standard rotors from a Mustang donor. I replaced mine with the Wilwood brake upgrade but I don't recall the old rotors with that much play. The center hub makes the rotor concentric so it will run a true circle.
    ALL of my brand new rotors on the 33 have that much play - the FFR kit ones and the new rotors I added to my 8.8.
    TBH, this looks normal to me.
    slpro1207's Avatar
    Moorpark, CA
    Quote Originally Posted by Melb-Mike View Post
    These are new rotors. Part of the IRS kit from FFR. It may not be a big deal. Just seems like they would shift back-and-forth.
    Quote Originally Posted by slpro1207 View Post
    They won't shift with the wheels installed and the lug nuts torqued down. As long as the center hole is a decent fit and they run true as mentioned, there shouldn't be an issue.
    The standard Mustang lugs are, I think, 14mm. Remember you replaced them w/ the 1/2 inch that came in the kit? This accounts for the difference.
