When I was mounting my rear wheels today I noticed I had a lot of play in on to rotors. Is this normal?IMG_0249.JPGIMG_0250.JPG
MK4 delivered 2/24/2017. Complete kit #9023,IRS, Power Steering, Leather, heater, 17" wheels, sway bar ft & rr, tremec 600 and Gordon Levy Racing SBF 427. First start and go kart 8/19/2017. Graduated 1/15/2018
MK4 #9230 complete kit delivered 1/27/2018. IRS, PS, leather, Tremic 600, SBF 427. Graduation 10/15/2018
MK3 #5253 donor bought unfinished. SBF 331, T5 Trans.
Sure looks odd. However, once the wheels are tightened down, play around the wheel studs doesn't matter. I'm assuming these are the standard rotors from a Mustang donor. I replaced mine with the Wilwood brake upgrade but I don't recall the old rotors with that much play. The center hub makes the rotor concentric so it will run a true circle.
ALL of my brand new rotors on the 33 have that much play - the FFR kit ones and the new rotors I added to my 8.8.
TBH, this looks normal to me.
The standard Mustang lugs are, I think, 14mm. Remember you replaced them w/ the 1/2 inch that came in the kit? This accounts for the difference.
