Results 1 to 7 of 7
Thread: Therma Barrier
    Senior Member jwebb's Avatar
    Longmeadow, MA
    Therma Barrier
    Looking for suggestions/recommendations on thermal barrier for foot boxes, floor boards, etc., ideas?
    Raleigh NC, OIB NC
    Quote Originally Posted by jwebb View Post
    I used ThermoTec, a bit pricey, (Summit, JEGS, Amazon) on all the heat facing sides of the boxes, firewall & inside of the trans tunnel. Live in Carolina & have had excellent results.
    Interior was done in Reflectix (Home Depot) under all the carpets.
    Kevin
    MKIV #8234
    This is discussed in dozens (literally) of threads. Here are a few. More links inside these. Even more on the other forum since it's been around longer.
    http://thefactoryfiveforum.com/showt...ation-Question
    http://thefactoryfiveforum.com/showt...sound-and-heat
    http://thefactoryfiveforum.com/showt...our-engine-bay
    http://thefactoryfiveforum.com/showt...-sound-barrier
    Senior Member DaleG's Avatar
    Mar 2013
    If it's not too hard on your budget:
    This for the engine bay side of the footboxes and firewall: https://www.summitracing.com/parts/the-13590/overview/
    This for the entire inside of the cockpit, and underside of the tranny tunnel top (it will really quiet the car down): https://www.summitracing.com/parts/dyc-10455/overview/
    Ohio
    I went with the koolmat from breeze. It came precut and very accurately too. It is a little pricey but does the job. Attaching carpet to it was easy with silicone as it allows for movement to get the carpet in proper location.
    JRL16
    Leesburg, Va
    I used Dynamat. It does go on sell periodically at Jegs and Summit.
    Doug
    FFR 7995
