Thread: Can someone with coyote post pic of area under steering shaft for me?
    Prairieville, Louisiana
    On outside of firewalll, directly under the steering shaft. I may want to mount my power brakes pump there but wanna make sure nothin needs that area before I go start making plates and running tubing. Thanks in advance!
    '33 Hot Rod
    MK4 Roadster
    Oct 2014
    Vermilion, OH
    Svtfreak, I hope this helps.
    CVOBill
    It certainly does, Mr Bill! Thanks.
    Do you have the extra pillow block for your steering also, to clear the coyote?
    '33 Hot Rod
    MK4 Roadster
    Oct 2014
    Vermilion, OH
    No extra pillow block with the headers that came with my kit. The previous owner got the engine and headers from Tasca Ford in RI and they came with adapters to connect to the FFR exhaust. The headers tuck in pretty tight and the steering has a lot of clearance. IMG_6161.JPG
    CVOBill
    Thank you sir. I'll just have to wait and see what to do with mine then lol.
    '33 Hot Rod
    MK4 Roadster
    Senior Member H R Lucky's Avatar
    Jun 2012
    CrossRoads, Pa.
    SVT,
    Here is a picture of mine.
    Nevin
    Nevin, AKA H. R. Lucky
    33 Hot Rod sn 524 build started 3/18/2013, First Start-5/09/2015, Go Cart-6/01/2015
    5.0 Coyote engine, 9in. Ford rear, 4 Link, Wilwood 12in. front brakes
    AC, power steering, FFR 17/18in. Hot Rod wheels
    Thanks, Nevin!
    '33 Hot Rod
    MK4 Roadster
