I'm using a '99 donor, which I stripped myself. The donor had taken a hit in the rear which meant limited access to the fuel tank and no way to disconnect the harness from the fuel pump/sender.
I'm sending the harness to Art for dieting, but need to find the male side of the pigtail that connects to the fuel pump harness.
The picture below shows the female side, which comes off of the fuel pump hat. I need the male counterpart, which is part of the harness.
If anyone has one or knows of a source to get one, I'd be most appreciative.
Shep
