0
0
E-Stopp Electric E Brake
Has anyone installed this Electric Ebrake? My Mark 3 has never had a working Ebrake. The handle ends up where it's hard to reach and takes leg room out of the tight passenger seat. Sems pretty pricey but I'm thinking about it. I've got room for another switch on my dash and it might integrate with my remote keyless ignition.
I have one in my car because the Wilwood discs with the drum type parking brake take far too much cable pull to work with the Lokar handle I tried. The E-Stopp fixed that problem. It's set up so the the brakes cannot be actuated with the engine running. It can provide some anti-theft protection if the button is hidden. It does require quite a bit of length for the unit, the cable that comes out of it and the two into one cable adapter.
I installed one on my 818. Works well.
- You may not post replies
- You may not edit your posts
Forum Rules
