Results 1 to 2 of 2
Thread: electric windows
    Mar 2015
    Belmar, NJ
    electric windows
    Looking for help adjusting the electric windows. I seem to have a gap at the top of the window and rubber molding.
    AdjustIMG_1477.JPGIMG_1478.JPGIMG_1479.JPGIMG_1480.JPGIMG_1483.JPGing seems to screw up the entire window and I start all over again.
    Spent 4 hours today and almost ready to throw in the towel
    818S #343 Delivered 5-20-2015
    First Start 10-17-2015
    First Drive 10-17-2017 ( 100 feet back and forth until I can get off driveway)
    First Drive with a non leaking tuned motor 11-12-2015 (wow)
    Passed NJ State constructed inspection 8/30/2016
    Do you mean the gap between the window and the hard top window frame, or is there a gap between the window and the felt gasket (can't see one in your pics)?
    It took a long frustrating while to get my windows close (and they don't look as close as yours). I did try installing the window track with the supplied hardware 'backwards', and in my case it closed up the gaps some.
    The biggest problem I found was caused by the curve of the window glass, which makes it very hard to get good alignment at both extremes of travel. So I focused on getting the alignment as good as possible when the window was closed, and I limited the downward travel a bit to keep the window glass aligned/pressed up against the felt gasket.
